Cases Lian Li PC-A70FB
Discussion in 'Hardware' started by happyhammer7, 7 Jul 2011.
  1. happyhammer7
    happyhammer7 What's a Dremel?
    19 Oct 2009
    Anyone know anything about this case? my mate stumbled across it (on Scan???) and asked me if it is suitable for watercooling. Personally I have no idea as I have not watercooled a PC et and whether this would be suitable.
    Have to say, it does look oustanding (without the blue LEDs that it :p)
  2. azrael-
    azrael- I'm special...
    18 May 2008
    I guess it's this one he's thinking about. It's pretty nice, which is almost a given with a Lian-Li case (although from time to time they release some real atrocities). In my humble opinion it doesn't hold a candle to the PC-A77F, though.
    As for watercooling, I don't know since I do also not watercool my PC. It's a pretty roomy case, though, so I definitely wouldn't rule it out. Especially considering there's room to put a PSU both in the top and in the bottom of the case.
  3. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Due to the way the drive cages are laid out and the lack of roof fans it doesn't lend itself to WC quite as much as the 77F, but i can definitely see room for at least a 120 and a 240 in there. You could get up to a 480 in the top along the horizontal bar but it wouldn't get a lot of airflow. You should check out if any of Lian Li's replacement top panels are compatible with the model.
