Modding Lian Li PC-A77 mod: Project[Thessa] Dual Loop Madness
Discussion in 'Modding' started by knet370, 19 Jun 2008.
  1. knet370
    knet370 What's a Dremel?
    19 Jun 2008
    Ok..A little introduction if i may..Basically, the goal is to watercool the case all internal without ruining the case's simple and minimalistic design. Yet maintaining a cool and quite system. The system will be overclocked to its highest stable clock(3.4ghz) on stock vcore.
    So i present Project[Thessa] < named after my significant other as a tribute for financing this whole project. LOLZ! ;-D
    Loop 1: Ek Res 250> MCP655>TC PA120.3> Q6600> NB> SB (EVGA 680i)
    Loop 2: Ek Res 150> MCP655> BIX II 240 > 2 x EVGA 8800gts 512mb (Will Be changed later to BIX II 360)
    Pics! :)
    Top Mounted PA120.3
    Lasercut Acrylic PA radgrill
    Powdercoat done..mounted the res and top rad
    front rad mounted in custom hd cage bracket
    window cut
    misc mods
    thats it for now..some minor adjustments will be done later..
    the parts i will be using
    tubes will be replaced to a tygon 3400 1/2id 3/4od on compression fittings on the cpu block. the rest of the fitting will be the dangerden fatboyz
  2. knet370
    19 Jun 2008
    i think i posted on the wrong section? Im very sorry. Is it supposed to be on the Project Logs Section? MODS, please delete this post.
  3. nicocsgamer
    nicocsgamer What's a Dremel?
    17 Jul 2008
    How have you cut the side pannel for the window ?
    Thanks.
