Reviews Lian Li PC-O11 Dynamic Razer Edition Review
Discussion in 'Article Discussion' started by bit-tech, 25 Apr 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Mr_Mistoffelees
    Mr_Mistoffelees The Bit-Tech Cat.
    26 Aug 2014
    Would be much better if the bottom filter slid out at the front, Like FD Define cases, instead of having to tip the case over.
  3. Gareth Halfacree
    4 Dec 2007
    Sadly, t'ain't the case for my Define Mini: it slides out of the back, which is a definite design flaw. Dunno if that changed in the newer Mini S.
  4. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    The base O11, I think, is probably the best value for money case out there atm - in terms of build flexibility and quality.
    The Razer edition is actually rather tastfully done for once, too.
  5. Mr_Mistoffelees
    26 Aug 2014
    I didn't know it was different on the Mini.
  6. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
    RGB then go an stick bright green on the front.
    Good thinking design team.
    MLyons likes this.
  7. jb0
    jb0 Minimodder
    8 Apr 2012
    "as the lighting is digital there's full control over every LED"
    In my ongoing one-man campaign to ensure words have meaning, I'm going to say that's not what digital means. It might actually be the exact opposite of what digital means.
    Mr_Mistoffelees likes this.
  8. Combatus
    16 Feb 2009
    I hear you, but here it's just a term given to the 3-pin addressable RGB malarky that does allow control over individual LEDs - I guess the term digital refers to the fact that each LED usually has a circuit built into it. The likes of Phanteks and Gigabyte refer to them as 'digital' Asus and Cooler Master use 'addressable', some such as Corsair use either or depending on the product and Kolink (see the Phalanx case review that just went live) uses digitally addressable :hehe: We could look at sticking to addressable in future reviews.
Tags: Add Tags
