Case Mod - In Progress Lian Li PC-O9 - Maximus Leader in a glass house
Discussion in 'Project Logs' started by Sharangir, 27 Oct 2016.
  1. Guest-16
    Guest-16 Guest
    Yes this. It's a lot of work and nice result, a pleasure to look at on the desk no doubt, but the cabling needs some attention. Some velcro ties or cable combs will do the job, esp as you went to so much effort with the SATA power. I usually have this, let it sit for a few weeks and go back to it with 'fresh eyes'.
    Nice work on the lighting too. Where did you buy the dimmer?
  2. Sharangir
    Sharangir What's a Dremel?
    18 Oct 2016
    Hey kim, thanks for the feedback :)
    What do you mean by "more symmetric"? With regards to colour choice, or the routing of the cables?
    Because there's a little baggie with cable combs lying in front of me right now.
    GPU and CPU cables will each get 2 combs to clean up the routing slightly. :)
  3. kim
    kim hardware addict
    10 Jan 2016
    ohh, don't worry, your color choice is nice, it was the cable routing, but I misunderstood it was not achieved yet, I think those cable combs will do the job perfectly
  4. Vault-Tec
    30 Aug 2015
    Yeah it needs combs. Great work though.
  5. Sharangir
    18 Oct 2016
    Ran two benches while waiting for Vega...
    CPU should be running at 4,6 GHz and the GPU is at 1120/1500MHz
