Hardware Lian Li PC-Q28 Review
Discussion in 'Article Discussion' started by Meanmotion, 1 Aug 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. koaschten
    koaschten What's a Dremel?
    24 Mar 2011
  3. phinix
    phinix RIP Waynio...
    28 Apr 2006
    I like it. VERY nice case. Lots of potential for modding. Watercooling too. Imagine it with small ST45 PSU.... nice....
  4. faugusztin
    11 Aug 2008
    So in short it is PC-Q08 with a different front (PC-Q28 covered the front fan, the fan has to draw the air from the bottom instead; the ports got relocated to the side), board mount holes are on two aluminum bars instead of the side panel and they added the bottom HDD mount thingy, which gets thrown out on at first build anyway :D. And they didn't fixed the biggest issue with these cases - 8 of those damn small screws per panel :wallbash:.
  5. Floyd
    Floyd Wire Twister
    4 Dec 2008
    This one only has 6 retarded screws on the side panel!
    Its one thing I hate about my only Lian Li case.
  6. Combatus
    16 Feb 2009
    Unfortunately one of the threads stripped on the PSU which meant the vertical mount (and gravity) were enough to make it droop ever so slightly. We only noticed it was slightly out of alignment afterwards. Sorry about that! Should not have impacted on the cooling results at all though.
    As for screws - it's just one guys - the others hold the mounting pins in place
    4th para -
  7. Meanmotion
    16 Nov 2003
    Apologies all round. I mistakenly changed this during subbing.
  8. abezors
    abezors Lurking since '08
    21 Apr 2010
    You're aware the case is "a fingerprint magnet" but didn't think to wipe them off for the photos! Looks like someone's been eating Doritos before the shoot...
  9. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Last paragraph:
    Your*
  10. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    As far as cooling design goes that case looks awful. They should have flipped the psu and added air intake on the side panel.
  11. fluxtatic
    fluxtatic What's a Dremel?
    25 Aug 2010
    If I were building a low- to medium-end build, why the hell would I splash out on a Lian-Li case?
  12. faugusztin
    11 Aug 2008
  13. wafflesomd
    22 Oct 2005
  14. wolfticket
    19 Apr 2008
    Low to medium end performance wise doesn't necessarily mean low to medium end in other respects.
    You may want a small system that, while not requiring a high performance, is in a prominent place. So you want it to look good and fit in with it's environment, which might mean spending an above average proportion of the overall budget on a high quality case.
  15. rollo
    rollo Modder
    16 May 2008
    Pretty much what wolf says is correct.
    Ive built htpc builds with much more expensive cases than the components in them in the main of things.
  16. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Hmmm... While I can see the points of both Rollo and Wolf I don't agree with them. Even if I was only going to use low to mid range components for the build if I was spending that much on a case I would want it to still be able to handle high end components for a potential upgrade at a later date. I would want my case to handle anything I may throw at it while it is sat there looking nice as I would hope my case would out live several rebuilds, with maybe the exception of the PSU and possibly storage components.
    There are plenty of perfectly good and well built cases out there for a lot less that look just a nice as the Lian-Li that are sufficient if you are only using low to mid range components.
  17. Xir
    Xir Modder
    26 Apr 2006
    I wonder why all the companies are concentrating on mini-ITX and letting out Micro-ATX which is just a smidge bigger but you actually get gamer and enthusiast boards for it. :confused:
    This one maybe isn't but most mini-ITX cases would be big enough anyway.
Tags: Add Tags
