Case Mod - In Progress Lian-Li PC-V354B - 27 Feb new photo
Discussion in 'Project Logs' started by Ced-G60, 6 Jan 2011.
  1. Ced-G60
    Ced-G60 What's a Dremel?
    15 Sep 2010
    Bringing up some more sleeving work, hope you like as much as I do :p
    Power Sata
    SATA 6Gbs Round cable
    SATA 3Gbs Flat
    8pin CPU
    Et voilà !
  2. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    This is incredible!!
  3. Raiden
    Raiden Portuguese reviewer
    26 Oct 2009
    Good skills mate ;D
  4. bobisgod
    bobisgod What's a Dremel?
    19 Apr 2010
    That has got to be one of the nicest sleeving i have ever seen:thumb:
  5. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Epic sleeving :D!
  6. Ced-G60
    15 Sep 2010
    :blush:
    Thank you for the support, really appreciate it :)
    Am open to any remark or suggestion too ;)
  7. Ced-G60
    15 Sep 2010
    Small update (yea, sleeving take time :p)
    I had a change of mind on my SSD placement. I think it look better and will make my cable management easier. I'll work out some kind of cover for the top.
    Front cable management. (don't mind the dust)
    And some more round SATA cables.
  8. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    love the MDPC red sleeve <3 Well done mate, nice tidy job there :)
  9. Ced-G60
    15 Sep 2010
    Thanks :D
    Its actually Color-X from MDPC not the red one ;)
  10. KidMod-Southpaw
    28 Sep 2010
    This looks great. Great job on the sleeving. I sure hope that you have a window to show all this off.:hip: How did you sleeve the sata power cables?
  11. Matticus
    Matticus ...
    23 Feb 2008
    Really nice clean job on the sleeving. It is nice to see that even though you are going the "normal" route of sleeving each individual cable, you have chosen a nice, smart colour scheme.
    The mix of those colours has something about it, it looks quite classy and up market. As classy and upmarket computer cables can be anyway :hehe:
  12. Ced-G60
    15 Sep 2010
    Thanks,
    Yes I have a plan for a window on it. For the sleeve on the Sata cable, I use some Sata sleeve, need some practice to fit them over the big round SATA 6Gbs but its ok.
    Thanks mate :)
  13. Ced-G60
    15 Sep 2010
    Small update, got my fan and couple other small parts.
    Enermax Magma x5
    I changed the rear PCI bracket to this. Like ?
    And some white led strip. Its going to completely hidden in the build, just to give out enough light to make a see trough with the smoked side panel.
  14. KidMod-Southpaw
    28 Sep 2010
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    Nice sleeving mate, I hope I get as good results when I get ready to do mine :D :thumb:.
  16. Ced-G60
    15 Sep 2010
    Thanks guys ;)
  17. Zanib
    Zanib What's a Dremel?
    6 Jan 2011
    very tidy, crisp an clean :)
  18. Evenge
    Evenge Minimodder
    16 Sep 2006
    Nice sleeving, I like those colors also!
  19. Ced-G60
    15 Sep 2010
    Thanks again ;)
    Little update:
    Finished all the fan, the 2 front one took longer as I had to extend the cables.
    Am going to make some custom sticker for the fan, because the photo speak for it itself, It need them badly :p
    Read PCI bracket installed
    That all for now. more soon
  20. Guest-16
    Guest-16 Guest
    5* from me. Very nice!
