Case Mod - In Progress LIAN-LI PitStop T60 Red
Discussion in 'Project Logs' started by Corsaronero333, 10 Mar 2012.
  1. Corsaronero333
    Corsaronero333 What's a Dremel?
    25 Feb 2012
    LIAN-LI Pitstop T 60
    Here we are ready for yet another adventure, well going to take 'into consideration a feast of Lian-Li.
    Fasten your seatbelts
    Do not smoke
    prepare the popcorn
    Following the beer
    and .......... good vision at all
    Ermanno
    Let's start with posting the material, the case
    Continue the presentation of the case:
  2. Corsaronero333
    25 Feb 2012
    OCZ Power Supply
    Now we will examine the power supply from 750w un'OCZ that will go 'part of this mod
  3. Corsaronero333
    25 Feb 2012
    Asrock motherboard
    now we move to the motherboard necessitudine staining I chose this card, fits perfectly with the mod and certainly will make 'his voice heavy lifting the cpu frequency to very high levels
  4. Corsaronero333
    25 Feb 2012
    And the adventure continues, but I'm going to submit another Harware, but rather the essential components that will dissipate the Lian-Li
    We start with the arrivals from Aquatuning
    We begin with the pump, is a Koolance PMP-300 is the small but pushes much
  5. KidMod-Southpaw
    28 Sep 2010
    Oh come on!?
    I just had to pick my jaw up off the floor from your glass project, and now I have to get ready to do it again?
  6. Corsaronero333
    25 Feb 2012
    Now we turn to the flow, but this will be 'only visual, but there will be' a controlled dall'Aquaero xt
    As I said this is only a factor esthete and will be 'enlightened, I removed the original and I placed an LED RGB LED
    You guys are a step above the lines, we are speaking of red anodized aluminum passive heatsinks, small Carello of photos and for working in the next post
  7. KidMod-Southpaw
    28 Sep 2010
    This is just too cool!
  8. Corsaronero333
    25 Feb 2012
    ahahahahahahaah thank :rock:
  9. Corsaronero333
    25 Feb 2012
    I can not put the thermometer and the fans are from Micro 40x40mm, rock 'also add the liquid of Nanoxia
  10. Corsaronero333
    25 Feb 2012
    Consider the passive heatsinks, as you see them coming, then for them to adapt to my mod I had to do some little hole
    Armed with the tip of 3.25 and male M4 I am going to do one of the first working
  11. Corsaronero333
    25 Feb 2012
    Ok place, the processing of the thermometer in the upper eheheheh
    Then you get a nice clean job I fitted a piece of paper tape that I put where I am going 'to cut to fit, and with a little' of sound patient I cut with the DREMEL
  12. Corsaronero333
    25 Feb 2012
    We're back to upload, today we examine the so-called shark fins term given by friends, guys here the work is long and containing many photos, I hope 'they just do not fall asleep ahahahahaha
    Before processing "Aluminum" we speak of a panel dell'ACRyan satin black and a red
    Working as a first line them with the 80mm nastrocarta whole area of ??work, in my experience I know 'that the only film sometimes is not enough to protect from scratches especially if using jigsaws.
    Once coated is passed to the drawing or tracing on the panel, is preparing the work area (a chair with 2 planks of plywood) and the work begins
  13. Corsaronero333
    25 Feb 2012
    Here is the most 'delicate tracing of the holes of the fans are cutting and bending
    Drilling ...............
    And here are the twins ready for further processing
    Here now we continue to place the media as the first finished work
  14. Corsaronero333
    25 Feb 2012
    Now, let us casting off, bending, it affects the side so as not to incur abnormal folds and then with a little 'tug of war .... and the fold is ready
  15. Corsaronero333
    25 Feb 2012
    Beat the fans are 40mm and see what comes out ........
  16. KidMod-Southpaw
    28 Sep 2010
    This is too much for me, so awesome!
    Now stop going so fast! :D
  17. Corsaronero333
    25 Feb 2012
    First phase was successful, the second pass, we prepare the coating media
  18. Corsaronero333
    25 Feb 2012
    Are you sure?
    The mod is very long and impressive :dremel:
  19. Corsaronero333
    25 Feb 2012
    Once assembled, we see that effect are also illuminated
  20. Corsaronero333
    25 Feb 2012
    We see a beta assembly:
