Let's talk about the base, and even the fans are 40mm should be able to get some air, but from where? begin: 1 2 3 4 5 6 assembled Air outlet fans are
LED changed from blue to red, very good for the mod. Indeed removed the system's magnetic flowmeter sensing koolancee added a nice red LED with extension and 2-pin plug fan, resistance is hidden inside the flowmeter
Carbon arrived .............. And then it just works in wax pack in a piece of carbon cloth as standard .... manopoli the fantastic as you think, we will see some good in the future ............. However, here we are once more work with the pieces 'large 250mm x 500 mm and down' processing ......... what do you think? as someone pointed out to me the difference of red aluminum I have radically changed the facade.
Now I take up the first base and start satin with hand-sanding paper from 120 to opacizzarla, and already 'we are preparing the first shelf with the loops Well, support for the flow of Koolance, I wanted to do virtually the same as the filter media so maybe the idea will be placed near the same design
Recessed flow meter and filter Here is a wonderful process to say the least (for me), the collection of two instruments in the basement, the parade begins. - First we start with the mark position, then check and limit moves the whole thing as I did, reducing the space between the two accessories:
The mod is finished, the first test and kept a quiet 2600K 5000Mhz. tests continue to fail to understand the limit of passive
Now the adventure begins, marking the first sheet of carbon and then down 'of DREMEL with diamond blade
