Modding Lian Li rivet sizes?
Discussion in 'Modding' started by Da_Rude_Baboon, 2 Dec 2003.
  1. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    Hi
    Does any one know the size of the rivets that hold the top on a Lian Li case?
    I'm looking at the rivet kit from maplin which includes 2·4, 3·2, 4·0 and 4·8mm rivets and the gun. Are these compatible?
    Thanks,
    Da_Rude_Baboon
  2. bsodmike
    bsodmike Banned
    11 Oct 2002
    Why not drill 'em out to 3/4mm and use some lurvly socket head cap screws? Would look much more pimp!
  3. Da_Rude_Baboon
    28 Mar 2002
    Could do but no one will ever see em.
  4. bsodmike
    bsodmike Banned
    11 Oct 2002
    Now I'm confused? or is it cause you removed the rivets to take the top off and you want to fit it back on? :duh:
  5. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    the 4mm dia rivets will be fine but make sure that they're long enough for the thickness
    ive just riveted my pc60 back together but cant remember the exact length of the 1's i used
