Cases Lian-Li T1 "Spider"
Discussion in 'Hardware' started by azrael-, 1 Mar 2010.
  1. azrael-
    azrael- I'm special...
    18 May 2008
    Don't know if anyone here has already seen this new conconction from Lian-Li. Every once in a while someone at Lian-Li must really lose all common sense ("Burj-Al-Arab" anyone), but this one takes the cake. I'd say they took a leaf out of Antec's "Skeleton" book, but found that concept a bit too wishy-washy.
  2. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I think there was already an article about this here on bit-tech
    BTW the video is not great
    edit: who benches on a mini-itx board
  3. jason27131
    jason27131 Lolzers
    6 Feb 2010
    Ya I don't really like it. looks too... flimsy.
  4. Jux_Zeil
    Jux_Zeil What's a Dremel?
    30 Apr 2009
  5. Showerhead
    Showerhead What's a Dremel?
    11 Jan 2010
    Still looks like it would collapse if you put a decent sized heatsink on it.
    Someone should mod it with motorised legs. True mobile computing.
  6. Jipa
    5 Feb 2004
    I can promise you 7/10 techies couldn't be arsed to mount a motherboard while testing if it works and of the remaining 3/10 2,5 wouldn't use this over-engineered waste of space. Besides, it's still just a mini-ITX, which alone makes it a silly product.
    ...Which is a bit like winning a coma-patient in a boxing match. :wallbash:
  7. Jux_Zeil
    30 Apr 2009
    You have to look past the 'before you eyes' and add a mobo tray with thread-less stand-offs. That way a professional who wants a mobile flexible unit, can fold it up PSU and mobo tester attached, call at the customers place of work/house and can appear to take good care of their expensive motherboard and CPU.
    Just an idea.
  8. memeroot
    memeroot aged and experianced
    31 Oct 2009
    I simply dont care, I would buy that case in a second if it went on the market.... girls will think your cool and have sex with you if you have that case (and tell them you designed it) they will NOT do that with an antec 902 regardless of the cooling potential of the top mounted fan
  9. The_Beast
    21 Apr 2007
    no matter how you shake a stick at it, it's still only an mini-itx format, which for most people (99%) is useless.
    most who bench use itx or large motherboard
  10. Guest-16
    Guest-16 Guest
    Im getting one of them :D:D:D muahah
    Good Lian Li promotional material/case :thumb: it's just what it needs. It's not a serious "case".
  11. Jux_Zeil
    30 Apr 2009
    Do a review?........Pretty please?
