Hardware Lian Li Tyr PC-X2000
Discussion in 'Article Discussion' started by Guest-16, 23 Jul 2008.
  1. fathazza
    fathazza Freed on Probation
    20 May 2002
    how much? :)
  2. naokaji
    naokaji whatever
    8 Dec 2006
    for my taste it's too big, I'd prefer the smaller x500 version.
  3. Stonewall78
    Stonewall78 What's a Dremel?
    21 Oct 2005
    I have wanted a case that has the bays on the side for years but after seeing this wasteful layout I am rethinking the whole idea. The case is huge and way larger then it needs to be. People are going to have a hard time fitting this into an entertainment unit to use it as a HTPC. Really the idea would work better as a desktop but it is way too tall to use in that form. Overall a fail in my book.
  4. p3n
    p3n What's a Dremel?
    31 Jan 2002
    Sure there is loads of space, surely its far too tall - why don't they have the hard drive section behind the motherboard with the hdds flat or something; taking 30cm off the height of the case but making it 5cm wider?!
  5. ParaHelix.org
    ParaHelix.org What's a Dremel?
    19 Jun 2008
    I have the Lian Li PC-P80 (black version) and despite what people say you really dont know how great it is until you actually see it with your own eyes. LIAN LI ROCKZ KEEP IT GOIN YEZZ!
  6. kenco_uk
    28 Nov 2003
    Do want muchly. I think, as stated in the review, that for the proposed cost of it, it should be nigh on perfect. I love the layout, the hard drive bays in particular. It's a shame there are only two 5 1/4" bays although with the layout I can't see how any more could be made to fit.
    I also think they should at least have put it on wheels. Even if it's completely aluminium, a loaded system is going to weigh a fair amount.
    I've just skimmed the review, looking more at the pretties, tbh. But one issue I can see is the cables for optical drives. How long would they have to be?
  7. bob_lewis
    bob_lewis Lurker extraordinaire
    9 Jul 2008
    Yay, nice review! Would be nice if you could review the smaller X500 too.
  8. Jasio
    Jasio Made in Canada
    27 Jun 2008
    Unfortunately Lian-Li does it again... an awesome looking case, but either rushed or simply ill thought-out execution when it comes to cable routing, and the little niggles like the bowed front panel should have been easily caught. I'd expect "issues" like that to show up in a $40 case, not a $375-400 case. This is what keeps me going back to Coolermaster and Thermaltake (Cosmos S, Stacker 830, Armor+) over Lian-Li cases. The Lian-Li PC-P80 on the otherhand seems to be an ideal case for me, it's a shame it's $400, which is rather difficult to consider when the very sexy Cosmos S is floating around $200. Dear Lian-Li: Drop your prices, for the sake of us all.
  9. azrael-
    azrael- I'm special...
    18 May 2008
    How about the PC-X500? (http://www.lian-li.com/v2/en/product/product06.php?pr_index=260&cl_index=1&sc_index=25&ss_index=62)
  10. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
  11. jhanlon303
    7 Sep 2006
    It's too tall, it's got the opticals on the side, it rattles, cable management will be the pits, needs wheels, weird fan size for WC! But ..... It's black on the inside instead of bare aluminum(sp?), and it's a Lian-Li ... I want one!
    John
  12. ssj12
    ssj12 Minimodder
    12 Sep 2007
    and when are you going to review the NZXT Khaos Full Tower case?
  13. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    Sucks. Horribly.
  14. DougEdey
    5 Jul 2005
    bindi: Where's the XB01?
  15. Nature
    Nature Minimodder
    21 Nov 2005
    BIT TECH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    What happened to the saphire 1600xt ultimate !!??!!?!?!?!??????
    I demand satisfaction!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  16. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    It is virtually the same dimensions as the monolith, very cool.
    Another interesting tidbit that is off topic, I only discovered my mobile phone is exactly the same dimensions as the monolith, Sony have some very cool designers.
  17. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    hmm I wonder if its possible to get a hold of the HDD cage that they use with the built in plugs... going to shoot them an email would be great for a project Im working on :)
  18. Sumanji
    Sumanji What's a Dremel?
    2 Nov 2008
    Hey,
    What's the HDD vibration damping like? No mention of rubber grommets, so I guess drives mount directly onto the plastic rails? I recently did an SFF build with the HDD mounted in the 3.5" bay, and within 5 minutes I had to order a 5.25" mounting kit with grommets... for me vibration is far far more annoying than fan noise!
    Tempted by this case a lot, but this is the *only* thing putting me off...
    Cheers,
    Suman
  19. Guest-16
    Guest-16 Guest
    As far as we can remember, no, no specific hard drive vibration reduction. But this is straining our memories a bit - we don't have the case any more sorry.
  20. Sumanji
    2 Nov 2008
    I was looking at the smaller X500 which is smaller, but does feature four 3.25" bays which definitely do have dampened fittings. Still weighs in at a hefty £200 though...
    You reckon it's worth the price premium?
Tags: Add Tags
