News Lian Li unveils PE-550, PE-750 SFX-L power supplies
Discussion in 'Article Discussion' started by Gareth Halfacree, 11 Apr 2016.
  1. Gareth Halfacree
    4 Dec 2007
  2. David
    7 Apr 2009
    Are these re-badged Silverstone units?
  3. Vault-Tec
    30 Aug 2015
  4. David
    7 Apr 2009
    Strikingly similar when you consider the connectors/colour of the ports and the type of cabling, but the fan grille and stated outputs are different.
  5. Hustler
    Hustler Minimodder
    8 Aug 2005
    Lian Li 750w Platinum, yikes!!
    ..expensive, bet you won't see any change from £150, which I suppose will be worth it for the Lian Li enthusiast.
  6. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    I'm not overly thrilled, I don't know who their OEM is but anything from Lian Li that isn't an aluminium panel is pretty hit or miss. The cable routing grommets in my case are the nastiest thing I've ever seen and I'm not a fan of the fans that came with it.
    The warranty will also probably be whatever stores are legally obligated to provide in your country as the company is virtually unreachable.
  7. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    ^It will be interesting to see who their OEM is and UK pricing for these units. Somehow I think the current demand for small form factor PSUs will outweigh any cons like noise, warranty etc.
  8. edzieba
    edzieba Virtual Realist
    14 Jan 2009
  9. Luay
    Luay What's a Dremel?
    13 Jul 2010
    A crazy product for someone crazy enough to buy the upcoming dual Fiji card and try to fit it in a mitx case for a 4k/VR steam machine.
