the packaging. Comes with one aluminium cd bezel and one floppy bezel standard You can just see the shiny new wheels. Even the badge is made from Aluminium. the bottom of the case! This case even has its own hand-brake! The mechanism for removing the sides is sooo sweet I love it! You can see how they have compartmentalised the case to keep the HDD and PSU separated from the rest of the components keeping it much cooler inside! Ill bet a Dual Row Radiator will fit in there! The quick release mechanism for HDD removal. that quick release case side mechanism again! The Fan Shroud. Well quickly in conclusion this is simply the best thought out and built case i have seen in the flesh! the build quality is amazing all the parts fit perfectly flush together. There are also some innovative little touches that make this case perfect, release mechanism for the case sides, the PSU and HDD placement for cooling and the funky handbrake for taking tight corners at 80 mph! . In part thay have stolen the form of the case from the Apple G5 but hey! who wouldn't? it is a work of art! The only gripe i have is the non removable Mobo tray. Now to start modding with that new WACC kit!
It is a cool case. I have a black one, started modding about a week ago. http://forums.bit-tech.net/showthread.php?t=62286 If you are going to keep up the pics/detail you should start a PROJECT LOG. Best of luck. MS
no rubber hard drive mounting grommets = not interested (also someone should mention to lian-li that they were holding the design upside down )
Lian Li makes such good quality cases. Love um. Trying to get a Lian Li 6070 case for a project. Ajump has them for 154$ thats great considerd FrozenCPU.com has them up for 200$. You planing to mod that case?
