Lian-li v1100 16 June
Discussion in 'Project Logs' started by J0d3r, 12 Mar 2006.
  1. J0d3r
    J0d3r What's a Dremel?
    13 Sep 2005
    Hi!
    Z4114: Thanks, done it myself ^^
    Tha Bart Man: Thanks, the new lian-li cases look all very nice, and surely they get better air flow, Im working on the poor airflow that has the v1100, specially in the VGA side.
    alastor: Hehe, you are right, seems that I have to open some more holes. Btw the ATX cables will pass through here:
    I must open a hugher hole
    Thanks all ^^
  2. Dj Ovin
    Dj Ovin What's a Dremel?
    7 Nov 2005
    Looks great 'till now!
    Really like that case (1100/1200 etc.), so i like those kinda logs :)
    Mod on!
  3. z4114
    z4114 FACE!
    25 Jun 2002
    In that picture where you showed where the ATX cables will pass through, what is that black flap at the bottom back end of the case? Some type of brake for the wheels?
  4. J0d3r
    13 Sep 2005
    Hi, a few new things:
    Today i end at brushing the drive bay aluminum, the result seems good to me, sorry for the poor photo :(.
    I screwed too a new bay cover, where i want to fit the neon switches and all those stuff, I will use black/blue acrylic for it like the photo show.
    Saludos
    PD: thanks for posting at discussion thread: http://forums.bit-tech.net/showthread.php?t=109369
  5. J0d3r
    13 Sep 2005
    Hi!
    Thanks Dj Ovin :)
    z4114: Yes, its the brake for the wheels :)
    regards
  6. J0d3r
    13 Sep 2005
  7. J0d3r
    13 Sep 2005
  8. wahoomcdaniel
    wahoomcdaniel What's a Dremel?
    14 Nov 2003
    For the two brass connectors that were spray paoited silver, if you want a chrome finish, why don't you merely change the painted brass nuts with stainless ones that can be shined. The shafts of the connectors will be covered with tubing, so they will not be seen.
  9. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    Looks good, I liked the window. Very clean and simple. But your should have done the engraving on the inside of the acryl ;) like this
  10. J0d3r
    13 Sep 2005
  11. J0d3r
    13 Sep 2005
  12. J0d3r
    13 Sep 2005
    Hi !
    I drilled and screwed a thing to pass cables trough the aluminum, thats the result:
    Saludos
  13. J0d3r
    13 Sep 2005
    Hi guys, I was working today in a hand made grill for the top fans.
    Well, the first is a good design:
    Now, we fix the alu to the table for work with security
    Now we are going to start work :D
    First of all I drilled all the alu with a small drill, then I used a bigger one for make the definitive holes.
    That is the stuff:
    Thats how it looks when I end it:
    I used that cut-off disks for the grill:
    After cutting the edges I started to sand the imperfections:
    And well, thats how it looks:
    Thanks :D
    Please, post your opinions:
  14. J0d3r
    13 Sep 2005
  15. J0d3r
    13 Sep 2005
  16. yahooadam
    yahooadam <span style="color:#f00;font-weight:bold">Ultra cs
    21 Mar 2006
    like the new fan grill :)
    looks pretty cool :)
  17. J0d3r
    13 Sep 2005
    Well: done
    Saludos ^_^
  18. J0d3r
    13 Sep 2005
  19. yahooadam
    21 Mar 2006
    very nice looking dude :)
  20. J0d3r
    13 Sep 2005
