Lian-li v1100 16 June
Discussion in 'Project Logs' started by J0d3r, 12 Mar 2006.
  1. J0d3r
    J0d3r What's a Dremel?
    13 Sep 2005
    Thanks Fr4nk, i really appreciate that other lian-li vXXXX customer talk too about his experience with the air flow at those cases. Thanks :) :)
  2. yahooadam
    yahooadam <span style="color:#f00;font-weight:bold">Ultra cs
    21 Mar 2006
    hmmm bugger, i was thinking of getting a lian li (large) case beacause my cases airflow is pretty bad ....
    Time to re-think then :(
  3. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Great job! Everything flows nice. Esp the blue flames :hip:
  4. J0d3r
    13 Sep 2005
    Thanks mnpctech!, you are a master in the art of modding and its an honour that you appreciate our job.
    Honestly I must say we got inspired with your flamming, I love your work with air brush and your modding work in general.
    yahooadam, if you planning mod it, lian-li and good cases, but the vXXXX series does not got a good air flow.
  5. yahooadam
    21 Mar 2006
    dont feel like modding a brand new case, it would void the warrenty wouldnt it ... it seems a bit stupid you have to
  6. J0d3r
    13 Sep 2005
    well... whats modding if its not voiding warrantyes :p
    regards
  7. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    I reccomend haveing the rear fan as intake and the top fans as exaust. Less dust that way.
  8. Claas M
    Claas M What's a Dremel?
    29 Jan 2006
    if you've read the whole log you would know why he did it this way. READ the log and stop only watching pictures...
  9. J0d3r
    13 Sep 2005
    Hi mates! Ive been working a lot that week, Im preparing my modded case for Campus Party, so I have less time that I want. Well, the first I done that week is modding the back of cover of the 12cm fan. Not difficult, only cutting, sanding and gluing the mesh
    Then I started working on the CD lector of the case. I bought a CD SLim with an adapator IDE-SLim and worked on his cover and in his sopport to the case.
    I hope you like it.
    Ah, and when Im working my cat is gaining weight...
    Saludos
  10. J0d3r
    13 Sep 2005
    Well in two days I will recibe my new serillel, so I hope connect the cd slim @ sata. Next step is getting the acrylic for the window.
    regards
  11. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    I like what you did with the optical drive!
    Cheers, WarriorRocker
  12. Dustin
    Dustin What's a Dremel?
    22 Apr 2006
    I hope you light that tubes up good!The internal part seems pretty empty :thumb:
  13. Neji
    Neji What's a Dremel?
    3 Jan 2006
    Yeah, the optical drive is a interesting semi-stealth. I like it.
  14. J0d3r
    13 Sep 2005
    Thanks! Today I recibed and installed the serillel, but unffourtanetly it does not match the unit, so I used a IDE instead a SATA and the serillel is now in a box.
    BTW the result is good too, photos tomorrow :p
    regards
  15. Dustin
    22 Apr 2006
    forgot to tell you i love the pixelated front door paint effect.Looks so damn unique and own.If you have more ideas finish that theme!
