Guide Lian-Li v300 Graphic Card Mod
Discussion in 'Modding' started by koola, 26 Mar 2007.
  1. koola
    koola Minimodder
    11 Jul 2004
    If you own the case and have a recent PCI-E graphic card like a X1800XT or X1900XT then you will have trouble fitting the card in... it doesn't physically fit :duh:
    Tools Needed
    1. Hacksaw blade
    2. Cordless drill (any electric drill will do).
    3. HSS 4mm drill
    4. Flat file
    Step 1
    Locate the oval cut out in the lower section of the 5.25" bay holder on the left hand side.
    Using the hacksaw cut down the side until you reach the flat section (lower 5.25" bay bottom).
    Step 2
    Once both sides has been cut, the metal section needs to be removed. The easiest way to remove the section is to drill a series of small pilot holes.
    Step 3
    Bend 90° in each direction until then section snaps and you are able to remove it.
    Step 4
    File the remains flat.
    From this
    To this
    Step 5
    Vac up any swarf that came from the drilling, cutting and filing. Wipe the area with a damp cloth as small particals of Alu can still reside there.
    Now throw your system back in a hope your card fits ;)
    [​IMG] [​IMG] [​IMG]
  2. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    lol, nice. :thumb:
  3. bamboo
    bamboo What's a Dremel?
    4 Nov 2006
    Good job, :thumb:
  4. Crazyglue
    Crazyglue What's a Dremel?
    27 Nov 2005
    wow, i was thinking about getting this case, and i have a 7950gt in my mini pc, this could be extremely useful if i do get the case!
    Thanks so much!
  5. $$OmEGa$$
    $$OmEGa$$ What's a Dremel?
    26 Mar 2007
    Thats a great mod right there, good job! :D
