Lian Li vs Cooler Master
Discussion in 'Hardware' started by Drachnem, 16 May 2007.
Which case maker is the better?
  1. Lian Li is King
    40 vote(s)
    71.4%
  2. Cooler Master is King
    13 vote(s)
    23.2%
  3. Other
    3 vote(s)
    5.4%
  1. Drachnem
    Drachnem Minimodder
    15 Nov 2003
    My friend and I were fighting over which brand makes the better of computer cases for cooling, design, quality, and ease of installation. I have always thought Lian Li to be the king of cases, he says that it is Cooler Master, I am in the market for a new case and so this is an issue of mine where I need the input of other geeks like myself to help me come to a good decision.
    Start your engines....
    :clap: GO!!!! :clap:
  2. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    It's a tough one, tbh.
    Lian-Li have excellent build quality but they stick with clean, minimalistic designed cases whereas CoolerMaster like the more stylish cases.
  3. Krikkit
    21 Jan 2003
    As above, but I prefer clean minimalist cases - a clean, simple look is what I love, and that's what you get with a LiLi. :thumb:
  4. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    Gotta agree with Krikkit, I like some of the Cooler Master cases, but others are a bit too overdone. Overall I like Lian-Li's clean, sleek look about them.
  5. trig
    trig god's little mistake
    10 Aug 2006
    tie
    edit...changed my mind
  6. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    have to say the old coolermaster was the king, now however their cases have fallen quite a bit. lian-li and silverstone are what do it for me now.
  7. sui_winbolo
    sui_winbolo Giraffe_City
    25 Sep 2004
    I'd Lian-Li has the upperhand in quality control and design. But I love my Blue Cooler Master Wave Master to death. So I voted for Cooler Master. My case is my favorite case.
  8. THEkorean
    THEkorean 42
    10 Jun 2005
    lian li has better build quality by far, but still that dosnt stop me from loving my wavemaster
  9. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Lian Li is the sort of Lincoln/Caddilac of cases - they do the same thing as everyone else, but just that little bit better. I've owned a PC 76 before, and that beast smacked of quality.. but let's face it, as well built as they are, and easy as they can be to work with...
    not everybody can afford $300 a pop. This is where CoolerMaster comes in - look at the Centurian cases - for about what, $60 you get a decent looking case with good cooling, and that's bloody easy to work in. It may be steel, but still. Cheap and easy fits many bird's beaks.
  10. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Lian-Li, but both are good. It really depends on what features and style you're looking for in a case. :)
  11. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    Build quality, I wouldn't have a preference. Air cooling: Cooler Master. Water cooling and phase: Lian Li.
  12. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    CM due to the mahoooosive and very pretty stacker 830 range
  13. Guest-23315
    Guest-23315 Guest
    I'd only ever have a Wavemaster or a Black Stacker 830 from coolermaster.
    Lian Li are so much simpler and cooler.
    Also, ever considered Silverstone?
  14. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    I would seriously recommend that you check out the Silverstone TJ07/TJ09 they are incredible.
  15. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    I have worked with both and Lian Li have it buy a mile. The Old collermaster ATCs cases were nice but the Lian Li's of the same time period were nicer to work on. Apart from the original stacker and the wavemaster coolermaster have done nothing of any merit to lift them above the competion for a long time.
  16. Jipa
    5 Feb 2004
    So Cooler Master makes cases? :eek:
    ..Ok I knew that, but it took me a while to remember all the fugly stackers I've seen. 1 vote for Lian Li.
  17. Lian Li Lover
    Lian Li Lover What's a Dremel?
    17 Nov 2006
    I suppose it might be a bit pointless me voting in this
  18. DougEdey
    5 Jul 2005
    Lain-li for me.
    There was a short period where their build quality went to pot. Now it's sorted.
  19. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    Clean and minimalistic is stylish, IMO.
    (And the V2000 beats the stacker 830 up and takes its lunch money in looks, durability, and ease of use.)
  20. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
    I'm gonna go with Lian-Li on this. Somebody already mentioned earlier CM cases like the Praetorian and WaveMaster and Stacker (the originals, not the sequels) and they are damn fine, but that can't make up for the rest of the line. The rest of their cases have a lot of extra plastic pieces and "features" that just don't stack up to the quality of Lian-Lis.
    I just got a PC-7B plus for 80 bucks off of newegg and the quality is amazing. Every little thing you think about getting for your case, rubber edgin, 4->3pin fan adapters, even case fans for the most part, its already there!
