News Lian Li X1000 case seems almost perfect
Discussion in 'Article Discussion' started by CardJoe, 4 Jun 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. TomH
    TomH BELTALOWDA!
    28 Nov 2002
    Very, very nice. :)
  3. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    That thing is absolutely massive, what do you need all that space for?
  4. Skiddywinks
    Skiddywinks Minimodder
    10 Aug 2008
    I haven't read anything about the X1000. What kind of watercooling potential does it have, and is the X2000 any better suited?
  5. Paradigm Shifter
    10 May 2006
    I really like tall cases. Some of the current 'high end large' cases get cramped when they're full of kit. The more room to play, the better IMO. :D
  6. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    A big case will also have better airflow because they're less cluttered. Either that, or there's loads of room for watercooling kit :D
  7. Skiddywinks
    10 Aug 2008
    How about room for mount at least one triple rad? I have to admit, it looks very tempting. I will definitely be doing a lot of research when we get some reviews out.
  8. TGImages
    TGImages Grandpa
    11 Aug 2004
    I have to agree. In days past I had giant cases so I could put all sorts of stuff in them but never came close to utilizing that space. Many open slots and bays that never got used. For the last few years I've preferred something that will hold a handful of drives, 4 including optical usually being more than enough for me. As long as the case is also easy to work on and has decent cooling you've pretty much met my requirements.
    For someone who wants to cram in a bunch of drives and cards I can see where this would be a useful case but when most of it sits empty..... well......
  9. I-E-D
    I-E-D Minimodder
    28 May 2009
    Sexy, wouldn't mind finding out the cost of one of these.
  10. knyghtryda
    knyghtryda What's a Dremel?
    2 Jan 2006
    Im seeing quite a bit of room... but still no way of conveniently mounting a triple radiator. I took a jigsaw to my current case for that to fit, but I sure as hell dont want to cut this beautiful case.
  11. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    ya Im growing out of the server size and larger cases, I try to stick around a mid tower range to a smaller full tower size.
  12. Paradigm Shifter
    10 May 2006
    Eh, after a mate had his nice, light, small uATX system stolen when his flat got broken in to... I want big, heavy, back-breaking cases that no quick-on-his-feet burglar is gonna be able to tuck under and arm and run with. :D
  13. mrb_no1
    mrb_no1 Pie Eater
    15 Sep 2007
    lol.... my tower is a massive server one, but it has wheels so they could sit on it and push it down the street to their van if they wanted...i just like more space, so then it can be made to look nicer and allow for a slightly greater build up of heat that one might be punished for in a smaller case. plus i have 6hdd's and not all smaller cases accomodate that! love the look of this lian li though, if i can find some money again in the economic depression, i'd turn those front fans around, stick a 360rad in there and have me a wc setup, then it'd be front heavy :p
    peace
    fatman
  14. Elton
    23 Jan 2009
    I'm starting to get more and more fond of large cases.
    If only because I'm sick of working in the cages they call the Antec 300 and the CM690...
  15. Sublym3
    Sublym3 What's a Dremel?
    3 Apr 2008
    Although it is pre production, the addition of tool-less optical bays and expansion slots are good. But in general it looks worse than the X-2000 imho.
    Should remove the 2 SSD bays they just look out of place, and should the internal layout back to how it was with the X-2000. Do we know if they are going to put hot swap HDD cage in this one?
  16. naokaji
    naokaji whatever
    8 Dec 2006
    I don't like the position of the SSD mounts, I'm sure they put them where they are so you can easily show off your bank account breaking ssds to your friends, but I bet most people don't have any friends (or even enemies) that would recognize a SSD as such, so they could have just integrated the SSD mounting in to the regular HDD mounting.
  17. Rocket_Knight64
    Rocket_Knight64 Minimodder
    12 Feb 2009
Tags: Add Tags
