Hi there any one got one of the Lian Li 3.5" card readers LIAN-LI CR-33B BLACK ALUMINUM 3.5" 50 IN 1 USB 2.0 MEMORY CARD READER Wanting to no if thay are full size 3.5" long or short 3.5". can not find the size of it on the net. wanting to no if its holes are 60mm center to center and if it will fit my case. Thanks.
Ok found out the Lian Li card readers are 60mm long so guessing the 2 holes are like 25mm center to center.What I would like to no whats the mesurement from the front of the card reader to the center of the 1st set of holes. Thanks
