Scratch Build – Complete ⭐ Light Blade "It's still cool to air cool !
Discussion in 'Project Logs' started by DÈF¥âÑt¸.·´¯`¤, 11 Sep 2018.
  1. DÈF¥âÑt¸.·´¯`¤
    DÈF¥âÑt¸.·´¯`¤ Well-Known Member
    14 Sep 2004
    Cheers VT ty mate , it's not often i spend a lotta time on the rear end :eeek: but i thought this one needed the attention :naughty:
    Hopefully a big update and run for the finish line this weekend....
  2. DÈF¥âÑt¸.·´¯`¤
    14 Sep 2004
    Trying to bring this one home, still some small things to get done.
    One of them was sorting a mesh insert for the rear exhaust the other getting the Corsair hardware installed to control all the LED madness.
    I gotta say while you pay a premium for the corsair gear it's sooo easy to setup...
    The whole lighting effects come from a single 2 channel Node pro unit.
    LED output 1 Runs direct to the 4 RGB strips and LED output 2 runs to the Corsair Fan Hub and controls the 2 x 140mm LL front intake fans and the 2 120mm LL CPU cooler fans
    The 4 LED strips have been spliced into 2 separate runs to mirror the signal from the output 1.
    This gives the effect along the sides of the case and then up the front.
    With the rest of the wires installed the PSU cover can be sat in ( this will later get a latch and lock type system to hold it in place)
    For the Hyper 212 cooler i had wated to put some sort of cover on it.... but of late have decided that i much prefer the look of the "raw" cooler as this works better with the
    hot rod look of the over all theme... A coat of black was added to the outer parts of the heat sink.
    This completes the hardware with GPU TBA!
    The rear port grill is pretty simple, 2 Routed circles of plex with a slight edge trimmed from the insides, this will allow the mesh to sit and the 2 parts can be glued together.
    The mesh is some good old MNPC tech mesh ive had in the shop for many years now .
    The new unit simply press fits snug into the port.
    Pretty much finishes off the rear end
    As you can see by the screen all the LED effects are easily controlled by the iCue software
    Custom cables , GPU , centre caps for the front fans top window , side windows, bottom wire covers, still to go.
    cobalt6700 and Cheapskate like this.
  3. Cheapskate
    13 May 2007
    You forgot your rgb power cable. :lol:
  4. DÈF¥âÑt¸.·´¯`¤
    14 Sep 2004
    LOL you mean this????
    Yaka likes this.
  5. Vault-Tec
    30 Aug 2015
    So clean.
    All you need now is a Galaxy HOF GPU.
  6. Dr. Coin
    Dr. Coin Active Member
    13 Sep 2013
    :O (had to go old school on this amazing picture). This Is it light pipes or EL wire?
  7. DÈF¥âÑt¸.·´¯`¤
    14 Sep 2004
    Cheers VT ty mate :thumb: GOD i would love a HOF card. But don't wanna sell my soul to a brand to get it ...but if a certain rgb card was offered to me i could swap over to the dark side :p
    I think i'll just stick with something basic being as workshop pc and not my inside pc it really dosnt need to much.
    Ahhh i remember the old EL wire days :rock: jeeesus i can remember trying to cut and rejoin that stuff to make lightening for a case mod......what a nightmare :duh:
    Modders don't know how easy they have it nowadays :lol:
    That's just led light tubes ... jeesus they even stole that idea off me :sigh:
  8. DÈF¥âÑt¸.·´¯`¤
    14 Sep 2004
    Baby steps baby steps until my new cooler and sleeved cables arrive
    2 small new additions ..... more homage to old HP Case Mods :D
    Yaka, cobalt6700 and Vault-Tec like this.
  9. DÈF¥âÑt¸.·´¯`¤
    14 Sep 2004
    On the home stretch now
    Finally the Case Mod Pro Cables arrived... I went with the Carbon... i thought white would just look Cheesy.
    And it was time to do some Cable Management...... like all 3 mins of it :lol: Seriously i have never cable managed a case that was so easy to "Cable manage" :hehe:
    Anyways.. here's some amazing shots of the "Cable Management"
    As you guys can see i still have a bit of work to do on "that one wire":lol:
    MTC soon :)
    ifohancroft, Cheapskate and Vault-Tec like this.
  10. Cheapskate
    13 May 2007
    I should dig through the Corsair cases Bill has sent me an figure out what the black boxes are. -Not that I'm compelled to rewire an already dead-slow project...:worried:
    Worried about the wire: Dude, this is 100% about the case, not the hardware. :lol:
  11. DÈF¥âÑt¸.·´¯`¤
    14 Sep 2004
    LOL soo tru :) I'm winding the clock back 20 years and sending this thing to an event for show ...... ahhh the old days of lugging and sending case mods of to studios and magazines and events..... i swore i wouldn't do this again and yet.... here i am :D
    I say open those Black boxes :thumb:
    ifohancroft likes this.
  12. DÈF¥âÑt¸.·´¯`¤
    14 Sep 2004
    Back to the old girl for today :)
    Side Blades, I wanted to add some lighting that i could use to show off my Sequential Blinkers when this case goes to HIN this weekend :)
    As usual nothing toooo overboard :p
    I won't underglow these as i'm constrained by the bulk of the corsair led strips, i have ordered some better thinner strips, but they wont arrive in time.
    The design is really simple, 3 layers of plex, 1 middle of frost sandwiched by white .
    With the magic of routing and some wire and glue work .... 1 side blade.
    Only the one edge will light up for now, once the new strips arrive i reopen and wire in the under glow.
    For now these wont perma attached, and i'll wire them externally, so they can run separate to the case.
    Not much i can do about the dark spots for now, but they do look pretty cool running separate effects
    Even the solid colours look pretty nice.
    standard effects work in well
    But it's the custom stuff i want them for :D
    Cheers MTC soon!
    ifohancroft and Goatee like this.
  13. Cheapskate
    13 May 2007
    Have fun at the show. Be prepared for people having random seizures.
  14. DÈF¥âÑt¸.·´¯`¤
    14 Sep 2004
    Cheers mate ty :) i'll have the doof doof on for the car boys :D
    Just testing out the new interactive Corsair wallpaper.... the guys over in the corsair forums are doing some amazing stuff with LED's and wallpaper engine!
    Trying to raise the bar over there !
    Ive redone the side panel now to light fuller and under glow as well :D
    Turn your volume down !
    ifohancroft and kim like this.
  15. DÈF¥âÑt¸.·´¯`¤
    14 Sep 2004
    A few last minute touches before this goes to HIN's this weekend.
    Ive added a good old base to the case, this should help to protect the bottom blades from damage while on show.
    kinda gives it a weird hover boat effect.... but works well as a protective base.
    You prolly already spotted the new light blade on the bottom right :)
    Ive made these as an "addon" feature, this allows me to remove/upgrade/change later on.
    The units simply stick onto the side windows using D'sided white tape.
    and are connected externally via the hubs and usb cable.
    They run on a separate Hub, this allows me to run the lighting effects independent to the rest of the leds.
    There are sooo many different lighting effects as well as the active music ones.
    The case can have a different look to suit mood room colours and i'm hoping down the track even match in-game effects :)
    Some final pics before i take it too Hot Import Nights this weekend.
    Light Blade by Defyant.
    ifohancroft, Goatee and Vault-Tec like this.
  16. DÈF¥âÑt¸.·´¯`¤
    14 Sep 2004
    Audio mode is pretty tweaked!
    Ive reworked the side blades to sync in better with the front lights...
    Turn ya volumes down
    Some thing a bit softer.
  17. Cheapskate
    13 May 2007
    Do Megadeth. :lol:
    Yaka and DÈF¥âÑt¸.·´¯`¤ like this.
  18. abbas-it
    abbas-it We came, we saw, we mod, you awe!
    1 Jun 2011
    bloody aweseome, i love the light works. well done
  19. DÈF¥âÑt¸.·´¯`¤
    14 Sep 2004
    Cheers mate tyvm :) coming from you it is indeed high praise :thumb:
    mega what? :naughty: HP-MEGA!
    I should have closed this off ages ago. I recently stripped her down for parts but do have plans to make it my first hard tubed mod down the track.
    Thanks all who supported and followed along. :rock::rock::rock:
  20. Yaka
    Yaka Well-Known Member
    26 Jun 2005
    damn that is so beautifully clean. really like it alot
