Modding Lighted Strip
Discussion in 'Modding' started by SJH, 26 Dec 2003.
  1. SJH
    SJH Active Member
    24 Dec 2003
  2. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    I wouldn't say it could replace a CCFL since it isn't as bright as one, but you may be able to light up your case to some degree with this inside, or use it to light up dim spots in the case where a CCFL wouldn't fit.
  3. SJH
    SJH Active Member
    24 Dec 2003
    Thanks SteveyG, perhaps I'll spend an extra few quid and get a cold cathode light instead :)
    -Sam
  4. Shogun
    Shogun Banned
    18 Jul 2002
    i know everyone says bad things about ebuyer but whenever i have used them, they have always been fine. www.ebuyer.com
    £3 for a sound activated ccfl with dual inverter
    £2.50 for an extra tube and another inverter ( dont know why they include another one)
    I have bought 5 ccfls and all have been of good quality.
  5. Visualaid
    Visualaid New Member
    15 Apr 2003
    the strip gives a glow like el string but doesnt output light very well.
