Modding Lighting panel
Discussion in 'Modding' started by scq, 15 Apr 2006.
  1. scq
    scq What's a Dremel?
    4 Mar 2005
    How can I create an even lit - and most importantly, cheap, lighting panel?
    I've already decided against the use of EL panels, as they are expensive, and not very custom-sizable/cutable, or even strong (since I may need to mount stuff on the panel).
    I was thinking of using some sort of plexi with white leds or cathodes behind it. Unfortunately, all I have available to myself is clear plexi (1/4", I believe). Any ideas?
    Thanks
  2. Big_Adam
    Big_Adam What's a Dremel?
    6 Jan 2004
    er.....how thick is 1/4 inch in mm??
    anayway. depending on that you could put some LED;s around the edge giveing a nice glow. you can pick up packs of led;s off ebay cheap as you like. don't get them from the modding section tho they cost more.
  3. furqan
    furqan What's a Dremel?
    2 May 2004
    and inch is 2.5 cm so 1/4 would be 6.25mm
  4. scq
    4 Mar 2005
    Except that's clear plexi, meaning it won't be an even lit, white panel. Could I maybe sand it, or spray it with some sort of spray-paint finish?
  5. Navig
    Navig What's a Dremel?
    19 Sep 2005
    I've seen folks who have frosted clear plastic by 1) sanding 2) spray paint (frosting). The embed white LEDs and it'll be even to a degree.
    I believe most LCD's have a diffusion panel--if you can find a cheap junk'd one you could steal it from there.
    navig
  6. McKaamos
    McKaamos What's a Dremel?
    12 Feb 2006
    Sand it and use diffuse leds.
    So dont use those 15 degree angle ones, but 60 degree.
    Using a bunch of those should give you a pretty equaly lit panel.
  7. scq
    4 Mar 2005
  8. Nezuji
    Nezuji What's a Dremel?
    23 Oct 2004
  9. mattthegamer463
    26 Nov 2004
    Those panels were also lit with cold cathodes, not LEDs. Thats why its so diffuse, because those lights are very even to begin with. Combined with that "trick of the light" as well.
  10. mobius9
    mobius9 Minimodder
    4 May 2004
    keep in mind, also you can take the cathode out of its plastic tube so you can much more easily attach it to the side of a frosted acrylic panel. I'm not sure how well the spray on frosting works for this type of lighting, however.
  11. gbeeby
    gbeeby What's a Dremel?
    6 Dec 2005
    here's a cheap and easy way
    get a few metres of clear rope light (like £1/m)
    wrap it round in circles and sandwich between some clear acrilic and some mdf/plywood
    and hold in place with some hot melt glue
  12. scq
    4 Mar 2005
    Oh no. I know that the bamboos matched up, but I meant on the motherboard side, where its just a flat panel of light.
  13. mattthegamer463
    26 Nov 2004
    Wouldn't you still see the circles of brighter spots where the rope light is? There needs to be a amount of distance between the frosted plexi and the light source so it can spread and diffuse enough to not be visible.
