Modding Lighting question
Discussion in 'Modding' started by ThE-LyNX, 27 Jan 2003.
  1. ThE-LyNX
    ThE-LyNX What's a Dremel?
    20 Jan 2003
    I have a grid of holes (12 across by 13 down spaced about 10mm apart) that i want to light evenly.
    Placing a neon behind caused some of the hole to light TOO well with other being very dim.
    My question is would a piece of plexi with dimples drilled in it and lit by leds work well??
    x = led
    o = dimple
    ---x------x------x---
    I o o o o o o o o I
    I o o o o o o o o I
    x o o o o o o o o x
    I o o o o o o o o I
    I o o o o o o o o I
    x o o o o o o o o x
    I o o o o o o o o I
    I o o o o o o o o I
    hope you understand this
  2. Arcana
    Arcana What's a Dremel?
    25 Jan 2003
    given the fiber optic effect on a flat plexi with divots in it...sounds liek it would work....it may not shine out of the case much, but if you look through the holes you'd see the light.
