Electronics Lighting system
Discussion in 'Modding' started by RascalRusty, 20 Aug 2004.
  1. RascalRusty
    RascalRusty What's a Dremel?
    7 Jan 2003
    Hi guys, I posted a thread a number of months back regarding a circuit for automatically turning on the lighting in my house. (hence the thread for the relays!!!!) The system would work by have atwo infrared beams side to side across the doorway, this would pick up whether someone was entering or exiting the room, and a PIXE would monitor the number of bodys in the room, so that if 5 poeple entered and one exited the lights would not turn off, but if all 5 left the room the lights would turn off.
    Now, what i need help with is, can anyone think of a way, inwhich to cleverly over ride it, say for a bedroom when someone wanted to go to sleep. Now yes I could just connect it to a master light switch, but, you would have to turn this back on in the morning for the system to work, and I dont know about you, but I would keep forgeting, so i need a way of turning it off manually, but to reactivate in the mornings, or when automatic is needed :duh: :duh: does that make sense :eyebrow: :eyebrow:
  2. Lynx
    Lynx What's a Dremel?
    24 Nov 2001
    What you do is you have a momentary switch which you push to turn the lights off and either have it so that if you leave the system turns back on or when you push the button again the system turns back on
  3. RascalRusty
    7 Jan 2003
    like the sound of a mometnary switch, how do I make one of these, would I need to add to the program of the PIXE to know this is what it is
  4. RascalRusty
    7 Jan 2003
    any one :D
  5. Lynx
    24 Nov 2001
    You can buy a momentary switch. The easyest way to implement the method I surgested is to use an intterupt.
  6. RascalRusty
    7 Jan 2003
    what to just interupt the power supply or something??
  7. Lynx
    24 Nov 2001
    Use a software intterupt. If you dont know what that is you realy need to learn more software before building your thing.
  8. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    I wouldn't expect the code to be to complicated, an interupt might be a bit excessive. As fast as µCs run you might as well just poll the 1st beam, poll the 2nd, poll the switch, and then set the relay as needed.
