Modding Light's & Paint [pics]
Discussion in 'Modding' started by Keyser, 12 May 2002.
  1. Keyser
    Keyser What's a Dremel?
    12 May 2002
    My current case:
    There's one 10cm CCFL, and 2 Bright blue leds inside the door of the case.
    The side is handpainted, got the picture from the Thin Lizzy Album "Jailbreak"
    My current project is to add a window to the opocite side of the case, here's a PS preview of what I'm planing to do...
  2. Linkitch
    Linkitch What's a Dremel?
    11 May 2002
    nice ! did you paint it yourself ??
  3. Keyser
    12 May 2002
    Yes, it took me forever, i painted on my spare-time after work for a few weeks, it's all done by hand witch brush and hobby-paint.
    (yeah, i do have to much spare time :) )
  4. Stew
    Stew Disgruntled Postal Worker
    6 Mar 2002
    I have that album on vinyl too :dude:
    Nice Job! :lol:
  5. Cyberdome
    Cyberdome What's a Dremel?
    4 Jan 2002
    cool ! l337 ! nice work ... how i wonder if you can spray paint 'WitchBlade' ? even ROX !
  6. therider
    therider What's a Dremel?
    11 Mar 2002
    Amazing paint skills. I dont have the patience to do something like that.
    ride
  7. neuro
    neuro What's a Dremel?
    9 Jan 2002
    :dude: <<<
  8. Wyzzord
    Wyzzord What's a Dremel?
    15 Nov 2001
    Very nice job! From one artist to another!!
    I do wonder though, why the background was not painted?? Did you want to go for the more traditional look of the beige case or did you not care?? just currious!!
  9. Slink
    Slink B7
    7 Oct 2001
    lots of potential
    Nice work on the paint
  10. Daneo
    Daneo What's a Dremel?
    11 Feb 2002
    thats a great idea
    ive never seen anyone incorperate art into a window! cant wait to see :)
    add a bit of gausian blur, and noise to that layer, and you wont have to do that mod, people wont be able to tell that it was photoshopped ;)
    whats behind your grill to make it light up?
  11. Keyser
    12 May 2002
    The image is panited of an albumcover, the original background is actuallt more gray, but i left it beige to let it melt in with the rest of the case. This way i didn't have to paint the entire case.
  12. Keyser
    12 May 2002
    Re: thats a great idea
    In the bottom behind the grill there's one blue 10 cm (about 4") CCFL.
    and in the top behind the door there's 2 LED's:
    (i know, nasty wires)
  13. quack
    quack Minimodder
    6 Mar 2002
    That's pretty cool :) I have the same case but in blue. I'm planning to also light up the front in pretty much the same way as you. How is the CC fixed behind the grill?
    I've already swapped out the boring green and red power/HDD LEDs for bright blue ones (and they light up part of my room on their own when it's dark!!)
  14. BlackFlux
    BlackFlux What's a Dremel?
    17 Jan 2002
    kudos on the painting job. Very original!
  15. Keyser
    12 May 2002
    I glued it directly to the grill :dude:
  16. acron^
    acron^ ePeen++;
    15 Oct 2001
    Not knowing much about CC's (which is pretty bad being as i've ordered one) I would query that and say doesn't heat produced from the bulb melt the glue?
  17. Keyser
    12 May 2002
    I Glued it at the ends, near the cable-connections,
    The tube itself doesn't produce much heat at all, you can hold it your hand without getting burned.
  18. Lazy
    Lazy Meow?
    13 Nov 2001
    this is why they are called cold cathodes and not hot cathodes :lol:
  19. acron^
    acron^ ePeen++;
    15 Oct 2001
    Duh :) I was kind of asking for that one wasn't I?:hehe:
  20. Lazy
    Lazy Meow?
    13 Nov 2001
    :D yes you were, but i'm sure it has happened to everybody :D
