Case Mod - In Progress LiLi Tower......final pictures
Discussion in 'Project Logs' started by kier, 10 Apr 2011.
  1. kier
    kier -----------------
    1 Mar 2011
    LiLi Tower
    Hi there, this build is already started begin march, but really wanted to let it see on bit-tech
    It's called the LiLi Tower.
    I've always had a kind of love for the Lian Li cubes
    Not one but two Lian Li PC-V351
    One is new and the other one has some changes already
    First i wanna thank some sponsors of this build
    Mr. Freddy
    En Mr. Ruud
    Thanks to these guys my start is going to be a little faster and nicer. Thnx!!!
    The hardware
    - I7 920 D0
    - 6x 2GB Corsair DDR3 1600
    - 2 x EVGA GTX470
    - Antec True Power Quatro-1000
    - 2 x Aqua-computer Aquaero VF
    - Asus Rampage III GENE
    etc.
    Water cooling
    - 2 x Black Ice GT Stealth 240 Black
    - 2 x EK GTX470 waterblock
    - EK Supreme CPU block
    - 2 x EK-Multioption RES X2 - 150 Advanced
    - 2 x Swiftech 355
    - Tygon slang
    - Bitspower Fittingen
    And more.........
    The color is gonna be black and transparent
    Some pics of the LiLi's
    Number 1
    And number 2
    Number 2 is a little modded already
    the top ia gonna be different, not with these fangrills
    This is the only thing i have from this Lian, but it's not bad. Have some nice ideas for this ;)
    Number 1 is complete, this one is gonna be the bottum
    Psu and Hdd's gonna be under the motherboard
    The first idea was like this...
    But like this is better
    On top al the water cooling stuff is gonna be placed
    2 rads, 2 reservoirs en 2 pumps.
    Last week i did some measuring and drilling the rivets
    Sawn a piece out of the 5,25 bay for the cables from the gpu
    Gpu in it, already did the sleeving ;)
    Al of the remaining cables can be put behind the bay
    And these grilz will be put here with transparent fans with white leds
    Flipped the HDD bay, so now have space for 2 HDD's and a SSD
    Placed the motherboard tray, also flipped
    Nice slots for the cables
    This space is gonna be sawn out of the top. (formerly the bottom)
    The back is gonna be like this, but painted black and i need to get/make a plate for the gpu
    Always nice to get a new motherboard. A sweet little rampage
    The Asus Rampage III Gene
    fat box
    The motherboard
    Republic for gamers, for a non gamer ;)
    6 Slots on a small motherboard, i like it
    Fill it up, with..............
    the EK-RAM Dominator
    Shiny
    installed it
    Using a EK-Supreme HF
    And 2 Black Ice GT Stealth 240
    These are gonna be placed in the top Lian
    Fits perfectly
    Placed the motherboard in the lowwer Lian
    Not much space anymore, what is a good thing in this build
    And my 2 GTX470 in it
    Everything fits, in the top Lian i have a lot of space for the watercooling
    Now i needs to decide which reservoir i am gonna place
    This weekend i had a lot of sawning to do
    Almost nothing is left from the Lian
    The middle of the 2 Lians
    And the top of the Lian
    There gonna be 2 Aquaero's VF inside, for this 2 times a slot
    Put it al together and brainstorming again
    Made a little mistake, i tought that the aquaero,s where the same
    but the are different versions,
    So i had to drill the holes for the bolds again more to the left
    just a little bit different
    For the front 2 times a slot for the displays
    Had some Acryl covers for the aquaero, but the aren't the same color. So need to order 1 more
    The hole cover
    Made a acryl midplate. This times 2, one for the top and one for the midplate
    Did some drawning
    And drilling/sawning time
    Made holes for the cpu and the Rams and made a slot for the gpu's
    Removed the tape, needs to be cleaned
    And needs to straighten some lines, but this is the idea
    And the BP fillports, a total of 4. @ for the cpu and 2 for the RAM
    Second Lian on top, and more brainstorming.
    Coolermaster has givven me some nice stuff for my build
    A nice package with all kind of things
    80mm fans with white leds
    A nice psu tester (sometime i blow things up)
    With upgrade units, for more load
    Black screws and other stuff
    A beautifull mouse, the Sentinel
    And....... the turbine masters
    which gonna be placed like this.
    Also i had some black aluminium panels, so lets get to work
    everything measured
    Drilled the holes
    And placed on the back
    mounted on the back
    And the fans for the radiators are finished
    Power up
    The are real quiet, and a lot of air
    And finally my acryl has arrived
    So sawn everything and drilled the holes
    Top left
    Top right
    Left
    Right
    And placed on each other
    Turned around
    On each side there's gonna be brushed aluminium.
    Th original panels i have finished already
    Left
    And right
    That's all for today
    Grtzzz.
  2. Rodhizzle
    Rodhizzle What's a Dremel?
    9 Apr 2011
    Damn this is awesome.
  3. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    A lot going on here... been busy already with a nice phat first post.. nice start.
  4. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    I like this. I shall be watching...
  5. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    nice ! i was close to do something similar when i still had my lian li v-350
  6. Marcos_Viegas
    Marcos_Viegas Minimodder
    6 May 2010
    Really excelente project! :thumb:
    Keep going! :rock:
  7. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    I like this, I have one of these cases myself and using 2 for a nice WC build is sweet :D
  8. kier
    1 Mar 2011
    Thanks you guys, for the nice respons.
    Like i said before, this project is started at the beginning of march,
    and i have 2 or 3 major updates finished allready.
    Today it's time to post these update,s. Hope you like these to ;)
    After this update, i am almost at the same level of updating as i am today
    Brainstorming about the rads
    First i wanna to make some costum Brackets
    But dont think thats looks nice
    So i did something different, have maked a radiator tray
    Only need to Cut out 2 times a Rectangle for the airflow
    Made slots for the fittings
    Just like this
    Slots around the fittings
    Only need to connect the radiators together
    Some highflow fittings
    Looks nice i think
    And the one on the top
    The pumps are gonna be like this
    I did a lot of thinking about the reservoirs, and tried a lot of things
    I have spinbays, EK tubes 150 and EK tubes 250
    Had taken some pics what i had tried
    The spinbays like this
    The 150mm tubes
    Or like this
    The 250mm tubes, but then horizontal
    Was getting crazy about this problem, but then.............
    Not horizontal or vertical, but in a inclined position
    From the top. Have a lot of space in the middle for the tubes
    Left side. Pump with a lot of rotary fittings
    Right side, almost the same as the left. Only the tubes gonna be with a different angle
    i did some small stuff. I've tested the airflow through the mesh
    It wasn't that good, so i've sawn a piece out of it
    Needs a paintjob
    1 rectangle is bigger then the other one, this is because i dont wanted to see the suspension from the rads
    Also i had some Glostrings, nice stuff
    I hoped they where white, but they are bleu/green, but doesnt matter.
    Had to change my midplate
    Looks fine in the dark
    like this
    This is also coming in a vertical line in the front
    A nice glow, i think
    Purchased a FrozenQ reservoir. The blue one
    2 reservoirs looks good, 3 even better
    Nice light in it
    Only i have 2 different colors blue, sow need to brainstorm for that
    And need to make something for the pumps
    Also i have sold my 3 GTX470, and get some other nice gpu's
    Gtx480, really nice cards
    Nickel blocks on it, looks better with this build
    Very shinny backplates
    The hole thing is really havy, so need to make something for this
    On the corners maked a kind of pilar
    I am in love with the backplates
    i had some nice stuff been delivered
    I think it,s the last stuff i need to finish this build, i hope
    So what did i get in:
    Some nice aluminium fans, the NorthQ 120MM 3711WL Silent Tornado
    And some BP fillporten
    Zilver plugs BP pluggen
    BP links
    Aqua computer powerbooster
    And 2 bottles of Feser Aqua ultra water
    The fans are coming across the motherboard, pulling fresh air over the board
    Like this
    Painted the back black
    And i have played with the glostrings, i did made it some more blue
    Top vertical line
    And vertical line under
    Nice effect on the inside
    Played with the different light sources, fans with the white led and some other leds
    Ram cooler also white leds in it
    Yesterday i did the front
    The 2 push buttons. One for the on switch and one for the eject button
    Sawn a piece of acryl. and maked 2 holes in it
    Placed the front plate
    The plex behind the front is gonna be enlighted, so that you have a white ring from the button and one around the button
    Also placed the new acryl front for the aquaero
    Made the aluminium strips for the 2 aquaero's
    Placed everything. I think i gonna make some cover for it
    almost finished the front
    Dont know if i make the buttons black, or leave them silver
    That's it for now
    Grtzzz.
  9. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    This project is looking very nice. The work done so far looks very nice! I'll be keeping an eye on it, that's for sure
  10. MilOk
    MilOk What's a Dremel?
    18 Dec 2010
    pics ? =O
  11. kier
    1 Mar 2011
    Don,t know what Pbucket is doing?
    It looks like maintenance :(
  12. MilOk
    18 Dec 2010
    i use imageshack.us =)
  13. kier
    1 Mar 2011
    I wish i was !!!
    Getting a little bit tired of there problem :(
  14. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Hey kier :)
    Welcome to Bit-Tech also :D!
    I got photobucket pro, no problems here :!
  15. jhanlon303
    7 Sep 2006
    Photobucket maintenance problem - not kier's fault. They are scrambling to fix.
  16. kier
    1 Mar 2011
    Hi k.3nny, thanks.
    Nice to see some Dutch pro modders here ;)
    Yup, 2% of the Pbucket users had this problem
    I was one of them, but they solved this problem very nicely
    +1 for Photobucket :clap:
  17. jhanlon303
    7 Sep 2006
    Pics are back and now I can watch.
    John
  18. djzic
    djzic Bokehlicious!
    8 Nov 2010
    Good to see the LILI tower here! You know, the family :thumb:
  19. KidMod-Southpaw
    28 Sep 2010
    WOW, what a great start! That looks amazing!
  20. kier
    1 Mar 2011
    Ahh, more family members ;) nice to know i'm not alone
    Thank you very much :thumb:
    Because my pictures where offline for a while, i'm gonna treat you guys for another major update
    This time i couldn,t resist to fill the top section of my Lian
    The good thing of this build is that i can fill the both sections separate
    So i can do the leak test without my hardware under it, i had some bad luck with BP rotery,s in the past
    First i had al the tube in place, solid and flexible
    Turned the pumps, only need to make a nice bracket for this
    These connected with BP links
    For now connected with Tygon tube
    Did the same thing on the Other side
    Only a bit different for the higher placed radiator
    The FrozenQ res. also connected with BP links
    Nice in the middle
    And fill it up
    And yes, i had a leaking rotery under the reservoir
    not shocking, but need to exchange this
    Also placed some black fillports, just to see the looks of it
    Al the black fittings and fillports are also beeing exchanged by silver
    think it,s a nice effect, seems to be floating
    Dont forget the links between the gpu's
    Nice effect also is the illuminated edges from the slots
    Gonna be silver
    Placed the wc section on it
    and the other side with the gpu's also illuminated
    Using i bright white led
    Now everything is almost in place, i'am thinking to remove the FrozenQ reservoir.
    It's to much chaos, and to bright i think, so i have changed some big little things
    Removed the FrozenQ, just to get some peace in the upper section
    Instead of this i've made a piece of mirror acryl around the pumps to let it look like
    everything is one piece
    (The Tygon tubes are gonna be changed)
    Connect the pumps together, just for the looks. Has no function, but looks nice
    Just need to make a cover for the pumps
    Around the pumps the mirror acryl, for this i have cut out 2 slots to fit the pumps in
    Think this is much better with the FozenQ out. Now i made the top cover of the Lian
    Sawn the holes for the fillports and drilled holes
    Over this there's gonna be a aluminium cover, but i'm thinking about this for the shape
    Also been busy with my Be quiet psu.
    all the way black sleeving and give a little paintjob to the back
    And a little piece of me on the pic ;)
    Always beautifull Mdpc quality sleev.
    In the 5.25 bay mch room to put all the cables
    The curve for the motherboard cables
    De curve van de draadjes naar de mobo voeding
    Just needs to be shapened
    Cpu cables true the 3.25 bays
    For the cables from the gpu's i used flatcable
    Just like this
    Like i said before, painted the back of the psu
    Gonna make a plate, just to get it the same like all the other covers
    Made the links for the gpu's
    I am still waiting for silver fillports. When they arrived i can put everything together,
    and connect all the cables to the 2 aquaero's
    But the most cables are covered for now
    That's it for this time. See you soon ;)
