Wow that looks so nice, really love the effect around all the cuts in the acrylic where it glows.. cant wait to see the end pics!!
Update!!! Got my Shinny silver fittings, better than black Fortunately there are a lot of modders who think along with me. So my good friend Pascal came up with the brilliant idea. The SLI bridge out of steel, this after much polishing and you have a nickel look SLI bridge Unfortunately you do not see that much any more of it when the upper part is over it, but still a little bit. I have the psu lowered for a few millimeters to get a line with the side panel The hdd bay on the other side, I've painted it black. Also this is in line with the side panel Pretty cool effect the acryl edge under the aluminum plate I've Also made some adjustments to the top. The air that the turbine masters blow out in to the case must go somewhere. Thats why i've made slots in the top jigsaw and file come in handy And after much sawing and filing The end result For cables that are going to aquaero's. This still needs a cap over it. Then it was time to play around with the tubes. The small tubes first With silver fittings and fill ports it looks very nice now The GPUs also connected. Left to the radiator and right to the pump CPU connected Rams also Radiator for the GPUs connected And the pump. first loop is finished Other loop Top placed Tonight I think i'm gonna fill it up and test for leaks. Grtzzz.
Before filling, I have made a small change I dont like tubes crossing each other. So this is how it's gonna be
I don't know if I have mist something but what is the point in having two loops if you connect the pumps with each other? Though really awesome build I have to say Really nice effect with the EL wire. Have 2 of them myself that I'm thinking of putting to use. Also got 2 El tapes on my current chassis.
Nah, you didn't miss anything, i think. Connection is just for fun, and to get the pumps in one line there,s almost no flow between the pumps, all the pressure goes to the outlets on the sides from the pumps. Didnt like the original color of the wire, it,s to soft, have seen the red (pink glow) and the white(green glow) but with some adjustment it,s much better This night i filled the tower up, no leaks Just a little teaser for you guys
This is sweeeeeeet!!! using the 2 cases like that has worked so well. such a tidy and clean looking build. Well done mate...+rep
Wow! What an amazing build...I love it! I feel an uncontrollable urge to go out and buy three Lian Li's...Aarrgh! Shop are closed it's Easter...
Thnx my friend Good idea, when i wanna put some more hdd's in it, i am gonna place a third one on top And another update for you guys Update: filling Last night filled the first loop. Fortunately, without too much trouble, went pretty smoothly. I just had to tighten the reservoir. The teaser, a lot of air after filling A good flow through the ram and cpu block After a while, the fog began to pull away This morning filled the other loop. This went completely without problems Plenty of bubbles. And the GPUs are underwater Air bubbles were during the day all almost gone, but will still take some time before everything is out Some more pics from above. I also received a couple of times the request to show the hole case. So for the occasion, I put the panels back. sleeving and connecting cables has to be done and some other small time-consuming things. And I think to lasercut the side-and top panels, instead of to go messing around to get it right. These side / top panel gonna have a nice thin edge and different forms (I think) Lower aluminum panels are good like this with the acryl behind Top section is now with the acryl panels only Itself looks all right now, but still think the aluminum panels will be the finishing touch - Fans are still to be modded (circle center) - I / O shield also to do something with - And there's gonna be a backplate for the psu And front panels below needs to be made. Same dimensions as the two pieces as above That's it for now Grtzzz.
Update: The LiLi Tower is of course not on hold. Was only in doubt whether I would let the custom side panels to be laser cutted or do it myself. Hmm, gonna do it myself. Measured it 3 times before cutting Holes for the jigsaw And after a lot of cutting and filing, 1 x side panel. Others also made but of course in reverse For the front panel also drawn two pieces Panel 1 Panel 2 Side has been made and fit. It has the same angle as the reservoir The part below, only needs to eliminate some cables behind The right part And the front panel placed The display of the aquaero is blue now, I have been using dark blue filter Other one is still off, still needs to make the cable And some pictures when it was dark The front with ........ a blue cross Line passes through nicely Total shot He already runs now for two weeks very smoothly. Needs to do some small things before the final pictures But these will certainly come. Grtzzz.
