lillbrorsans first try
Discussion in 'Project Logs' started by lillbrorsan, 26 May 2004.
  1. lillbrorsan
    lillbrorsan What's a Dremel?
    26 May 2004
    So, i have never modded a pc before but i decided to go ahead when i saw this forum and the beautiful creations in it =)
    I have always been interested in modding a pc so i wanted to give it a go.
    I've got 3 guides from an very nice member and when i had read the 3 guides i started to get some ideas.
    -Some windows on top and on the sides
    -New holes for fans
    -Wheels underneath
    -And something thats still secret...
    This is the case:
    Measured out and used this plastic bucket to get the rounded corners:
    Then measured out a secret thing in between ;)
    Then measured out an place for a fan, the removal of the old leds spots and a new power button on the front:
    Its always something to start with :D
    I need some ideas for the place were the 3.5 floppy disk has been.
  2. dirtbiker
    dirtbiker What's a Dremel?
    24 Dec 2003
    Looking good!
    It might be an idea to resize the pics (800x600 is a good resoloution to use) and then use the tags so that we dont have to click the links... modders are lazy :D
    Good start though :hip:
  3. lillbrorsan
    26 May 2004
    Yeah sure ill do that right away
    Done :D
  4. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    Hi my scandinavian friend :)
    I like your ideas and work so far :) (can you just give us a hint on what the secret is? :D I'm dying to know!).
    God luck with your project :) I'll stay tuned :)
  5. LsdBoy
    LsdBoy What's a Dremel?
    14 Dec 2003
    Ooooo another guy from sweden..:) Nice...:)
  6. [OODBALL]
    [OODBALL] What's a Dremel?
    7 Oct 2003
    go sweden =)
  7. SuperFreak
    SuperFreak What's a Dremel?
    16 May 2004
    Sweden rules!!!
  8. lillbrorsan
    26 May 2004
    Well i havent really decided on the secret, but it can be a sort of a pipe...
  9. Jonas79
    Jonas79 What's a Dremel?
    13 Nov 2003
    Nice case to start with :)
    Where the floppy drive was you could put a rheobus.... or an LCD display... or a card reader.... or ports that you would want to access without crawling back behind your comp like headphone jack, USB, FireWire or whatever...
    Or you could add something completely different :D
    Mod on :dremel:
    (I didn't know we were so many swedes here :worried: )
  10. Goblin Tinkerer
    Goblin Tinkerer What's a Dremel?
    24 May 2004
    Good luck! Jump in and have fun! I think you will find it quite a bit easier than you first thought. I know i did. These comps only look complicated! Corse havent done any custome wiring and lcd stuff yet. Yet.
  11. Car Freak
    Car Freak What's a Dremel?
    26 May 2004
    Good start :) :thumb:
    Might get my own custom comp. soon
  12. lillbrorsan
    26 May 2004
    Anyone know a guide how to add a lcd display with all the cables, and then configure it?
  13. [OODBALL]
    7 Oct 2003
  14. lillbrorsan
    26 May 2004
    Thank you =)
  15. Tompa_
    Tompa_ What's a Dremel?
    6 May 2004
    Hello!
    Your idea sounds good but I cant see the images! :sigh:
  16. Peppo
    Peppo What's a Dremel?
    1 Jan 2004
    det där såg ut att kunna gå vägen =) GO sweden
