Electronics line follower robot
Discussion in 'Modding' started by kazama, 1 Aug 2008.
  1. kazama
    kazama What's a Dremel?
    9 Dec 2006
    hi, i want some advice on building a line follower robot. This is my project for this semester. I use a pic16f877a to control the robot. Now im in progress to search a circuit that is use PIC16f877a and also use servo or dc motor. I want to know which is better, using a servo motor or a dc motor?. It is because there is a competition among us, which robot is faster. Hope your advice make my project progress faster.
  2. Tec_
    Tec_ What's a Dremel?
    26 Feb 2008
    DC is the way to go. take a peek at the sandwich bot if you haven't seen it yet. it uses 2 dc motors and a comparitor to turn the motors on and off. 2 guys in my class built them from scratch for there projects
  3. jakenbake
    jakenbake full duplex
    5 Jun 2005
    i'd say servo...
    more acceleration
    more speed
    closed-loop
    the speed will probably rely more on the type of sensors you use and how you implement your control software
  4. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    A modded servo is the very best and also the cheepest method as it also has motor controller and feedback circuitry.
  5. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    Not sure if servo will increase speed due to the increase in processing time? However it will increase accuracy by a margin - which I suppose in return would mean less correction which would then save time.
  6. jakenbake
    5 Jun 2005
    If the PIC is running a 1hz clock, then it might affect it.
    Chance are its running a 4Mhz clock, which is 1 line of code every 25 micro seconds.
    Or 1 operation every 1 micro second.
  7. kazama
    9 Dec 2006
    Thanks for the respond. Im still blurred with the planning to build the robot. Still not start the project, because im still new in the PIC programming and in process to learn the PIC architecture. I have found a circuit, but not using a PIC that i'm using right now and i'm still searching the best circuit that is using either one of 2 motors that i have mention before. I'm also planning to use a colour IR sensor as a black line sensor. I have 4 servo right now, for saving my money i can use that servos. If not i can buy a dc motor. But the important thing that i need is a circuit.
    i have 2 sanwa RC servo, which is been taken from my RC car, i just want to know weather this servo can rotate 360. It is because i have read some articles about servo, and they show some pictures on modding the servo, so the servo can rotate 360.
  8. kazama
    9 Dec 2006
    My project is about 60% finish. But i have a problems with the coding. i just want to know on how to use pwm to set the motor speed. i think my coding i wrong. hope you guys can guide me to correct it. Here is my coding:
