linear worklog Alright, the exit polls show that worklog wins by a landslide, with 87% of the precincts reporting. So buckle up or hang on to something, cause here we go. Intro: Now that I've made a custom case, I just have enormous difficulty using a stock case as the basis for a mod. Making something from the ground up, realizing your own design, it's just too compelling and powerful--I'm hooked. So I'll be a custom case person for the forseeable future. I went so far as to start a case mod, but I got bored really quickly. Working with acrylic was great--I had a lot of fun learning the techniques, researching from the 'net and libraries, and talking to experts in the field. There is a wealth of info about acrylic and plastics, and more people than ever are using it for a material since it's cheap and easy to work with. So what's next then? I wanted another design challenge, a set of constraints that would lead to problems which need solving, the solutions to which would constitute a case design. And I wanted to work with a new material. Acrylic was a lot of fun, but the 'been there, done that' aspect of it was getting the best of me. I fell in love with small form factor when doing the invisible case, so I knew I wanted to do another small case. I had realized that the cube geometery led to a layout that wasn't as efficient as it could be. And the cube could never take expansion cards, which limited (crippled, more like) the video performance of the system. So I gradually formulated a new set of design constraints: smaller volume than the invisible case needed to support high-end video and optionally other expansion cards (video being the big motivator though) use standard components without modifications to the components incorporate dramatic lighting fx have a non-box-like form provide shielding from EMI (unlike the invisible case) use unusual materials And of course, with all the killer cases around, both modded and custom, it had to rock. The community seemed to be going through a cycle of jaded responses to mods, I wanted to sort of break up that cycle. So, I decided to make a case entirely out of carbon fiber. And by that, I mean composite material made of woven carbon fiber fabric laminated with epoxy resin. The fact that no one had done it was just a bonus. The weight was another bonus--they use this stuff in aerospace applications because of the high strength/weight ratio. I decided to add an arbitrary design objective to my list, to have my case weigh in under one pound. Minus the components, of course. Alright, by this point, I know you guys are tired of the blab, and wanna see some pics, but please bear with me. I just wanted to somehow explain my thought process and rationale behing this project, and give you a glimpse into how I conceive these rash undertakings. I'd never even seen carbon fiber composite material in person before I started this project, and honestly, that made it all the more attractive to me. I spent several months arriving at this point, refining my ideas until I was convinced that the kernel of a feasible project was contained in there somewhere. Then I went shopping.
I had done at least enough research at this point to know that no one had done a CF case. The overall perception was that CF (by which I mean composite material made from laminated woven carbon fiber cloth) was expensive and/or difficult to work with. Both are true to a degree. But it was pretty common to see comments on boards like "it would cost hundreds (or thousands!) of dollars to make a CF case" and "it takes specialized equipment." Both are wrong. I found several sources for the material (none local), so I spent a good deal of time reading price sheets and FAQ pages, trying to figure out what the heck I even wanted to buy. There are numerous grades of woven carbon fiber cloth available. Some are in fact quite expensive. Others are not. It came to my attention that there is a shelf life to the fabric, and it is occasionally possible to buy surplus material from aerospace applications that has exceeded its shelf life. So I found a supplier (I will reveal the source eventually, not just yet) who could sell me 50 inch wide, 2x2 twill woven carbon fiber cloth for $32/yd. That amounts to around $2.50/ square foot. Remember that a panel is a lamination, made up of several plys of CF fabric laid up in an epoxy resin. Keeping the case small became more than just a design goal, it became a budget necessity. So the next thing I did was to order two yards of fabric, and a quart and a half of resin. I had no idea at the time just how tight of a materials budget that was going to put me on. Of course that was one of the things I learned. While waiting for the goods to arrive (they showed up promptly) I went shopping for other tooling I was going to need. I needed disposable brushes and mixing pots and so on, plus supplies for cleanup and material for making molds. I bought wooden craft sticks (popsicle sticks), paper plates, cheap paintbrushes, mylar film on a roll, a couple gallons of iso alcohol, mold release wax, and some sheets of .093 inch acrylic. I used plastic containers from powdered lemonade mix for measuring cups (since we had a lot, and they were a good size). I also ordered a six foot length of one inch diameter acrylic rod, which I planned to use for handles.
Alright, I can hear you all screaming for the pics, so here we go. Here's the overall case design I came up with, including component layout. This is the final design and layout except that I added a half-inch to the width. What 3D software do I use? It's called pencil, paper, and rulers. Not shown on the drawings are the handles, which will be made from the acrylic rod. There will be four handles total, extending between the tabs on the front and back faces. In case you can't read the dimensions, 12.x6.5Wx10D is what I finally settled on for the box itself, the tabs add another four inches plus change to the height and width, but only of the front and back faces. That's 780 cubic inches in volume. Over 20% smaller than the invisible case. I set the actual dimensions up pretty much by the rules I lay out in my case planning guide. I started with the mobo footprint, added the width for the vidcard, then played with drive placements until I arrived at a solution that met my volume constraints. I found a TFX form factor PSU, which at 2.5x4x5 inches, is a winner for volume. It also has a fan that intakes case air and exhausts to the outside, so it's a key part of the cooling strategy. It will sit right atop the CPU/HSF, but with enough clearance that airflow will be minimally impeded. I decided fast that I didn't want to guess at the dimensions and get it wrong--my materials budget was pretty tight as it was. So I decided to make a 1:1 scale prototype using mat board from the craft store. At just over 1mm thick, it had enough stiffness to make a decent actual size mockup (plus it was cheap, and came in black). That's aFlexATX mobo sitting beside the prototype. The prototype was invaluable in getting my component placement refined--I found out this way that I need to abandon my ideas of fabricating panels with a radius curve. I needed the extra volume. Here's a shot from the side that would normally open for component access. I redesigned my panel placement completely after making the prototype--it really saved me from trying some things that were doomed to failure (and wasting material in the process). My original plan called for two clamshells to fit over the skeleton shown in the prototype pics. But it seemed wasteful to have a mobo tray when I could mount it to the side of the case. So that change saved me ~3 square feet of cloth. Here's how the mobo fits the case And here's a test fit for the drives. I'll be making a removable cage for this project as well. Picture in your mind's eye the PSU sitting atop the HSF. I couldn't mount it there for the pic, so you just have to imagine. OK, now that you have the basic feel for the case form and format, let's move along to....
...lighting fx. The rods were just begging to be lit up. And I had been looking for a way to use the Luxeon Star/O's that didn't involve either spotlighting something in a case, or having to look straight into the light. Shining them down the length of a one inch acrylic rod did the trick nicely. In full room light, this thing still glows vividly. It's pure red, don't get fooled by the pic--the camera's CCD saturates because it doesn't have the dynamic range of a human eye. With the lights out, it's just insane. It looks so good. There's no yellow at all, that's a camera thing again. One of these lights up my workbench pretty well--you could see to pick things up. Imagine sitting next to a case with four of these at a LAN party. And even though I decided to go with red (because they are significantly brighter) I did try this out with bloo: And I have to admit, it was a tough decision not to do blue. The color looks a little more true on this, and that's because it wasn't bright enough to saturate the CCD on my camera. So you should get the idea that those reds are bright. I ordered four from my supplier. The sureface of the acrylic rod I scuffed with a fine steel wool. With a polished surface, the rod just conducts the light, it doesn't visibly glow. I entertained the notion of red at one end, blue at the opposite end (with circuitry to cross fade the two colors ) but I had enough trouble justifying $60 in LEDs, let alone $120. Maybe if there's a sponsor out there....
okay, let's see some of this carbon fiber already. I liked the looks of 2x2 twill weave, so that's what I got. There are several weaves, and you can mix them together, so if you wanted, you could use a cheaper material for inner layers of you laminations since it won't be visible. You could even use fiberglass (or just about any cloth really) to save a lot of money, and just use CF for the top and bottom plys. But the weave isn't completely tight, and you can see through it if you look closely. Anyhow, I decided on 100% CF except for the handles. Here's the stuff on the roll. I found out fast that if you don't tape along the line you want to cut, you lose so much material to fraying it's not funny. That's about one yard of 50 inch wide cloth shown there. I burned up way too much on test pieces, so I started to carefully mark out my panels with narrow tape. (Actually, 3/4" tape I cut down to 3/8" with a utility knife.) Here's my setup for making panels. my paper plate for mixing the epoxy resin, the chip brush I used, the acrylic mold (there are top and bottom molds, and they are waxed with mold release), and a paper template of my front bezel for size. I'm ready to do what's called "wet layup." The first step is to coat the surface of the mold evenly with resin. I got stuff with a 30 minute pot life, and the consistency is about like corn syrup, it's pretty easy to work with when you're wetting out the cloth, not too viscous. Here's one ply wet out on the mold. I used three-ply construction on my panels. The weave doesn't let light through like it does with one panel. The more plys you add, the stronger (stiffer really) the panel will be. At three plys, my panels came out as stiff as typical case sheet metal or possibly a little more, which I figured was good enough. Here's all three plys fully laid up wet and the top mold in place. I put this between a couple scrap pieces of 3/4" plywood, and set a heavy toolbox on top of it. If you were a pro you'd have a vacuum bag setup, and get air pressure to do the work that I used gravity to do. I couldn't justify spending the couple hundred bucks to get set up to do vacuum bagging. So the key to the molds is that the composite panel completely picks up the texture of the surface of the mold. I used acrylic because it was a) cheap, b) flexible, which facilitated unmolding my panels, and c) glossy smooth. Glass would have met a and c, but not b. Mylar film is good too, but has no stiffness on its own. Here's the unmolded piece. It's quite glossy, but has a bit of residue on it from the mold. This polishes out pretty nicely. Check out the gloss you get from a polished panel: And the thing is, if you want matte finish, just use a mold with a matte finish. Here's some panels ready to be unmolded: And my last pic is of a bracket I made by laying up four 2-inch wide strips between mylar, and sandwiching the whole works into two pieces of aluminum extruded L-cheannel, then claming the whole assembly together while it cured: None of my pieces or panels are trimmed yet. Trimming the stuff is easy, it cuts like butter with a hacksaw blade. I've been cutting by hand. Dremeling works well, but produces a large amount of fine dust that is nasty nasty stuff to breathe. I like the larger sawdust made by hand sawing, it's easier to sweep up too. A couple more notes: Splinters are a real problem. Handling the material after the resin set up, you can easily get a single fiber that's impregnated with resin and cured to puncture your skin. Ouch ouch ouch ouch. A lot like fiberglass. The plain fabric isn't hard to handle (it's somewhat soft) but the stuff with resin impregnated is ouch. Panels with a bead or bend in them are much stiffer. If I weren't fabricating a skeleton out of L-channels, I'd use molds that let me put a bead in the panels. This stuff is really really stiff once the epoxy cures. Cleanup is easy with iso alcohol. I alway wet two or three paper towels before I start laying up panels. You can thin the resin with pure iso alcohol, but the consistency works good for me out of the tin.
I've got more to say, but right now I'm tired and will continue once I get some sack time. Comments and questions are welcome, but I will not be answering questions until after I finish this project. Thanks for understanding, if I took the time to respond to all the many questions, I'd not get any work done on this.
Nice to see everything on one page, that must have taken you atleast an hour to compile. Thanks Rob. -bliz
Cool idea to use carbon fibre Linear, I was always under the impression it was ridiculously expensive, but as it's just been proven, you cna pick some up really cheap. Cool. Also I love your case design, that looks really cool, and I like the lit handle bit. Good luck with your moulding and cutting and fitting, don't hurt yourself . . . . . . . . . . . too much Nice write up to, really good. Cheers for making it all nice and clear and such. Keep us updated, I want to see how this puppy turns out
Q : Are you gonna use the LCD viewing angle fix on this ? Might be good, some sort of panel on top, that will EJECT when you press a button - and lcd will project on it.
Alright, some more thoughts about carbon fiber as a material: * It's conductive. This is a plus and a minus for making cases. On the plus side, there's electromagnetic shielding properties that you don't get with acrylic or other plastics (or any non-conductive material). On the minus side, you have to consider galvanic corrosion effects when you come into contact with metal, especially aluminum. I read about this while researching--evidently bicycle manufacturers will use a ply or two of fiberglass if the composite part has to contact aluminum. I have a test piece that has been drilled and riveted with amuminum blind rivets for a few weeks now, and it's showing no signs of corrosion, but to be on the safe side, I'm usng non-metallic fasteners everywhere in this project. * It's thin. At least compared to the acrylic sheet I was using. I'm giving up very little of my volume to the case wall thickness. In case you blew past it in the narrative, my 3-ply panels are coming out around 0.7mm thick. * I'm doing several things differently from tutorials or other info you may read. For example, I'm not rotating my fabric to get the bias of the fabric dealigned between plys (which would add strength). My application isn't strength- or weight-critical, so I'm going the route that uses the least material. * Where stiffness is critical, you'll see a couple of design trick I developed. my original plan was to cast resin brackets to hold the handles, but I realized that laminating flat panels was a lot easier than making a proper mold, so my design evolved to be something constructed entirely from flat pieces joined with angle brackets, and there will be cylindrical brackets that hold the LEDs and handle rods. I'll show off a cool fabrication trick making the brackets. * I can't reuse my molds. The acrylic gets lightly pitted somehow by the epoxy resin. I bought enough acrylic sheet to do all my panels, although in retrospect, I'd just use mylar film to line the mold if I were doing this again (more flexible, disposable, cheaper and releases quite well without any prep). * It takes me about an hour now to make a panel, including measuring and cutting my cloth, preparing my molds, mixing my resin system, laying up the laminate, clamping it, and tidying up when I'm done. The resin system I'm using cures for 24 hours before I unmold it.
WOW!!!! I had always thought of making things with carbon fiber before but, like Kargin, thought it was to expensive. This is going to be an AWESOME case once your finished.
Truely masterful! Awsome Linear. Question: Why no curves? CF is flexible until set, you could have made some nice curves into it. I guess it would take more material cost?
If you read his posts you'll notice he says that he was going to go with rounded corners, but in order to make a small a case as possible, and have enough room for bits, he couldn't afford to lose the area in the rounded corners.
I don't want to sound corny or anything, but this is truly a project I can't wait to follow. It's set to look like a really unique case, and a lot more authentic than that fake stuff that everyone (myself included) uses
