Networks Linking Linksys RT31P2 to D-Link DGL-4300
Discussion in 'Hardware' started by iainharvey, 19 Jul 2005.
  1. iainharvey
    iainharvey What's a Dremel?
    19 Jul 2005
    Hi
    I have a D-Link DGL-4300 (Router 1) and a Linksys RT31P2 (Router 2). I only have router 2 as it is required by my VoIP provider (Vonage) to provide the service. Router 1 has my internet link. I have connected router 2 to router 1 by connecting the wan port of router 2 to a lan port on router 1. The VoIP service works perfectly in this configuration and all activity on router 1 is also running smoothly. All network connected devices have static IP addresses assigned through router 1. Also, DHCP is enabled on router 1 but disabled on router 2. The network IP is of the 192.168.0.x variety and all devices have IP addresses in this range.
    Here is my problem - I want to make use of the 3 lan ports on router 2. I have tried connecting two devices, namely an Asus WL-HDD and a D-Link DSM-320 Media Player, each of which were set to receive their IPs via DHCP. When I tried to use these devices after plugging them in, they could not get an IP. After reading various posts on the internet, I decided to swap from the wan port on router 2 to a lan port on router 2. The VoIP service promptly stopped working and I still couldn't get the two devices mentioned earlier to obtain IPs dynamically.
    Can anyone suggest i way that I can have my cake and eat it? i.e. VoIP and the use of the 3 lan ports on router 2 when it is connected to (and theoretically controlled by) router 1.
    I hope that info is sufficiently clear and detailed enough. Would appreciate any help you can provide.
  2. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    Connect one cable from the wan on router 2 to a lan on router 1 and connect a cable on a lan on router 2 to a lan on router 1 is the only way to get it done that i know of.
  3. iainharvey
    19 Jul 2005
    Thanks. I've done that and it seems to be working. I did consider doing that but thought it would be too easy.
    Cheers bud
  4. CaseyBlackburn
    27 Jul 2004
    Anytime, I'll always be here to help.
