Networks Linksys Router WRT54G need more port !!
Discussion in 'Hardware' started by ComputerKing, 3 May 2007.
  1. ComputerKing
    8 Sep 2006
    hello guys
    I have Link sys router WRT54G and it have only 4 wire port ! I want use more I got more computers here so I need more than 4 ports !
    I have cnet hub 8 ports I dont know if it works with it or what I need to get to have more ports ?
    thanks
  2. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    A hub would work, but it would be better to get a switch. Then connect the switch to the router and the computers can be connected to the switch or the router.
  3. ComputerKing
    8 Sep 2006
    mean I have to find switch with the ports I need !
    what's your advise with switch with 10 + ports ? which company ?
    and thanks for the help brother
  4. CarlT2001
    CarlT2001 What's a Dremel?
    23 Jul 2004
  5. ComputerKing
    8 Sep 2006
    ok Nice ! but this look like the cafe router :D
    I will go with d-link !
    thanks guys !
  6. sinizterguy
    25 Jul 2002
    Any make. I use a crappy thing called N-Link or something (an 8-port). Been working for reliably for over 4 years now.
    Go for a known brand name like Linksys or D-Link for more peace of mind. If you already have a 4-port router you will lose one port, but add on 7 with a 8-port switch (as 1 port on each as you will need it to interconnect the two). Should give you 10.
    You could go for two switches or go for a switch with 12 or 16 ports. But they tend to be more expensive and 2 8-port ones might work out cheaper.
  7. ComputerKing
    8 Sep 2006
    yeah I get you
    I will go with that link
    I think itsw good ? I dont need than 7 porst in use ! I have 5 computer more
    so its what I need
    thanks brothers very much :D
  8. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    That one should be more than good enough.
