Linux Linux Architectures and their accompanying Processors
Discussion in 'Software' started by OneSeventeen, 2 Dec 2004.
  1. OneSeventeen
    OneSeventeen Oooh Shiny!
    3 Apr 2002
    I have noticed that there are various architecture types sometimes overlapping each other and would like to understand them a little better.
    Here's what I know so far:
    For Intel and AMD 32 bit processors I would use x86 or 586.
    For AMD Athlon 64 and Opteron Processors I would use x86_64 and amd64
    For Macintosh PCs I would use PowerPC
    Is there a long list somewhere describing which architecture covers which processor?
    For example:
    I know I can use x86 and 586 on my AthlonXP, and x86 would work on an old AMD K6, but would 586 work on a K6?
  2. Lynx
    Lynx What's a Dremel?
    24 Nov 2001
    An Athlon is actually 686.
    But onto your actual questions.
    Everything is fairly straightforward if you dont use an x86 CPU (the architecure = your CPU (effectivly)). With x86 you have a few different varieties:
    386:
    Basically an arcitecture that will run on any x86 PC
    486:
    same as above but not on a 386
    586:
    is pentiums and above
    686:
    current generation
    Hope this helps
