Linux Linux based router/firewall
Discussion in 'Software' started by Lord_A, 2 Nov 2004.
  1. Lord_A
    Lord_A Boom baby!
    23 Mar 2002
    OK first of all...
    My name is Aris and I am a Linux n00b :lol:
    I had a quick search on here but did not find too much detailed information on what I want to ask:
    I have an old PC lying around that I would like to use a a router/firewall.
    What I would like it to be able to do:
    * Act as a good firewall, must allow me to allow/disallow individual ports (and possibly restrict bandwidth on some?)
    * Must have NAT and port forwarding (I believe this is needed for stuff like file transfers/audio/video in Netmeeting & MSN etc?)
    * Be able to support a USB ADSL modem - are USB modems in general compatible? I will be looking to purchase an internal PCI ADSL modem in the near future though if need be.
    * Be able to support at least 8 PCs mostly W2k & XP, but also Server 2003 & Win98 (I have a 10 port 10/100 Netgear switch)
    Questions:
    Basically covered in the above, I can explain further if need be.
    From reading the posts I found using search I get the impression that SmoothWall is one of the best?
    I had a look at Freesco as well but reading their FAQ reveals that Netmeeting/MSN audio/video etc functionality is not supported.
    (edit - disregard that they have an update which supports this)
    What do you Penguin users recommend?
  2. ajack
    ajack rox
    17 Apr 2003
    Smoothwall will do all of those things, as will IPCop. They're the only ones I have experience with and are fairly similar so give 'em a go.
  3. Lord_A
    Lord_A Boom baby!
    23 Mar 2002
    Thanks!
    I'll be giving it a go hopefully later today :D
  4. Skylined
    Skylined Minimodder
    3 May 2003
  5. fizban
    fizban What's a Dremel?
    11 Jun 2004
    I've used coyote linux it worked great before freesco develop PPOE support. Then I went with freesco until I was given a hardware router... now I use that. Less trouble :)
    here's another site that may be of interest too:
    http://www.routerdesign.com/
  6. simon w
    simon w What's a Dremel?
    3 Nov 2003
  7. simon w
    3 Nov 2003
    I've just found another software firewall called m0n0wall (which supports traffic shaping). It's based on FreeBSD and you can run it on embedded PCs with a CF card, such as this one which is only 124mm x 145 mm
    Here's what others have done it :hip:
    http://m0n0.ch/wall/gallery.php
