I have cable broadband, and a separate cable modem and router. The wireless on the router seems to have died, I have done various tests to confirm this. Is there any way I can use my linux mint / ubuntu HTPC (which is the only machine next to the modem) as a wireless router? All the other computers are running Windows (XP/Vista). Any suggestions will be appreciated.
Sure you can, add a nic to the PC and connect it to a cheap wireless access point. Software wise you'll probably need just a DHCP daemon and configure IPTables (for the NAT/Forwarding/Firewall) After that, the sky is the limit, DNS server, (transparent) proxy, ...
The HTPC has an onboard NIC and a wireless card installed now, do I need other hardware, or can I sort this out tonight? Ninja Edit: I'm a bit of a linux noobie, so don't assume too much!
And how do I find that out?! It's a b43 card, but I don't know exactly what drivers it's using since it worked immediately on Linux Mint (though not on Mythbunutu, despite both being Ubunutu-based).
Code: htpc jez # iwconfig wlan0 mode master Error for wireless request "Set Mode" (8B06) : SET failed on device wlan0 ; Invalid argument. Looks a bit like I'm out of luck! PS: (for confirmation) Code: iwconfig --help Usage: iwconfig [interface] interface essid {NNN|any|on|off} interface mode {managed|ad-hoc|master|...} ...
I know the ifconfig syntax but 'man ifconfig' will tell you even more And yes, no luck... You can still do the NIC + Wireless AP tough... Ninja EDIT: You didn't try it as root (with sudo), which is required...
I just included the usage snipet to confirm the syntax for this version of iwconfig. BTW, I su'd to root, so that's not it, I think it's my hardware.
Ok, my bad then. Your hardware is indeed the most likely, because only a few wireless cards (which are typically clients) can do master mode. That's why I initially suggested the NIX + AP route
brctl addbr br0 brctl addif br0 wlan0 brctl addif br0 eth0 ifconfig br0 <lan_ip> up http://www.linuxfoundation.org/en/Net:Bridge Is that not what you want?
As Glider already said, you are not running the command as root. As such it does not have the priviledges it needs to change the mode of the Wlan card. Run the command exactly as Glider wrote it. Including the sudo prefix. I included it here again: Code: sudo ifconfig wlan0 mode master
read his post again, he is running as the root account, sudo is unnecessary. note the prompt is a # rather than a $ i had wondered about doing this a while back, but after 30s on google dismissed it as impossible. i should have known you could do anything with linux. does anybody know of a list of cards that will work in master mode?
Code: htpc jez # ifconfig wlan0 mode master mode: Unknown host ifconfig: `--help' gives usage information. Code: htpc jez # iwconfig wlan0 mode master Error for wireless request "Set Mode" (8B06) : SET failed on device wlan0 ; Invalid argument. I have a weirder issue though: Code: jez@htpc ~ $ sudo ls sudo: unable to resolve host htpc ... This has only started happening recently. How is it that it can't resolve itself?! Fortunately, it doesn't seem to stop it from doing anything.
This is quite weird, as 'ls' doesn't require any resolving, it just lists the files in the current directory... Seems you have quite a borked install...
