Linux Box
Discussion in 'Hardware' started by richman, 1 Feb 2004.
  1. richman
    richman What's a Dremel?
    17 Sep 2003
    Iam going to create a box to put linux on as i want to learn how to use it and dont want it dual booting with my main box, would the following specs be ok for running linux
    Mobo: Gigabyte GA7VAX
    Cpu: Amd Duron 1.8
    Ram: 512MB
    HDD: 60GB
    Cheers
    Richman
  2. Darv
    Darv Bling!!
    12 Aug 2002
    That would be more than enough for any Linux box. Especially if you are only planning on messing around with it.
  3. Lynx
    Lynx What's a Dremel?
    24 Nov 2001
    You can linux on a P133 fine. So its kinda overkill :p Its perfectly fine
