Linux Linux Fileserver?
Discussion in 'Software' started by MightyMouse, 1 Mar 2006.
  1. MightyMouse
    MightyMouse What's a Dremel?
    21 Mar 2005
    I'm planing on makeing a fileserver, since my laptop is stuffed full of mp3's and I dont trust external HDD's as they tend to crash to often.
    I've can get a computer for free from work since i work at the IT departement at the local hospital and we've been getting rid of a lot of old computers, and setting up new Wyse terminals.
    Ofcourse since theese are all Pentium II or III at the best. My friend at work assures me that theese will do just fine as a fileserver with Windows server 2000 or 2003, but that would be too easy.
    What I want to know is if there's a Linux distro (or BSD i guess) that will be fairly easy to set up, work well on an old computer, and most importantly be able to make network shares that won't be any trouble getting too from a Win XP computer (preferably useing net use to make a network drive)
    - Mouse
  2. trigger
    trigger Procrastinator
    22 Mar 2004
    Debian would be a great choice, but if you're after something a little easier to set up and use, perhaps try Ubuntu.
  3. BjD
    BjD What's a Dremel?
    10 Apr 2003
    I have fileserver running OpenBSD 3.7 (upgrading soon, reluctant to spoil the 80day uptime ;) ) running on a Cyrix 600 downclocked to 400MHz & passively cooled. A Pentium 2 is going to be plenty of power for it.
    Really any flavour of Linux or BSD would be fine, I only went with OpenBSD to try something new. Debian or Gentoo would work fine, I hear Ubuntu has something tailored for server installs (? don't quote me on that).
    I share files out with Samba, works on every OS I have running here. Just "Map Network Drive" in windows, enter user/pass and you're away. Initial setup can be tricky when Windows is involved but theres plenty of guides out there to guide you.
  4. MightyMouse
    21 Mar 2005
    An other thing I'm ofc interested in is; will Linux make a better file server. i.e. use less resources, and make it a generaly "faster" server then what a Windows server would.
    (also realized this thread should probly be in the Linux ad Open Source category)
  5. trigger
    22 Mar 2004
    It really depends on how you run it. You can get rid of the Xserver (GUI), and all other services you don't need (as indeed you should on a server anyway), and it will be a LOT less resource intensive than Windows. But something like the default Ubuntu install will likely be equivalent to an XP install until you start cutting it down.
  6. gbeeby
    gbeeby What's a Dremel?
    6 Dec 2005
    Slackware rocks !
    quite easy to install to
  7. Guest-16
    Guest-16 Guest
  8. FuzzyOne
    FuzzyOne
    19 Sep 2002
  9. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Ubuntu has a server installation that doesn't install a desktop environment, and runs pretty light. Also quite easy to install.
  10. Goreblast
    Goreblast What's a Dremel?
    6 Apr 2004
    Windows 2003 Server is a pain in the butt. I have it here and am seriously thinking of ditching it and running linux when I can get reliable driver support for my Promise sx4000 Raid card.
  11. kiljoi
    kiljoi I *am* a computer king.
    13 Oct 2003
    :clap:
    I've got a web/file server running on Slackware right now, took me all of 3 hours to set up, including the Slack installation.
