Linux linux from 256mb usb?! possible?!
Discussion in 'Software' started by bixie_62, 20 Jun 2006.
  1. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    hey all
    was wondering if it was at all possible to boot a linux distro from a USB key. more specifically, a 256mb USB key!
    it quite simply needs to be able to access the internet as a priority and a file browser/network browser would be nice!!
    let me know what the linux guru's are a-thinking! am kinda keen to get into linux!
    ta :thumb:
  2. Glider
    Glider /dev/null
    2 Aug 2005
    Access the internet as in firefox or as in links/lynx? Because for Firefox Xserver is a dependency, and for Links/lynx it isn't, which makes a huge difference...
  3. Herbicide
    Herbicide Lurktacular
    27 May 2004
  4. simon w
    simon w What's a Dremel?
    3 Nov 2003
  5. dfhaii
    dfhaii internets
    24 Mar 2002
    Check out zipslack ( http://www.slackware.com/ ), it's designed to run from a USB key.
    'ZipSlack is a special edition of Slackware Linux that can be installed onto any FAT (or FAT32) filesystem with about 100 MB of free space.'
    Col
  6. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    i installed DSL on it but i cant boot off it on my computer. takes the pi*s
    i've got options to boot from USB zip and USB cdrom and USB floppy. no USB key. doesnt boot if i select USB floppy, cant think of anything else to try!
    its an ABIT av8 by the way!
    do mac's support booting from usb?
  7. Glider
    Glider /dev/null
    2 Aug 2005
    Try the other 2 usb devices? ;) cdrom's interface is the same as hd's... so that could match...
  8. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    Is there an option to emulate usb keys as floppy disks, might work.
    Moriquendi
  9. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    is there any way i can actually EMULATE an ENTIRE computer environment WITHIN windows?
    i'd like to be able to test the USB keys one by one (i may need to make in excess of 20usb keys with some form of linux on them) and i'd like to be able to test them without having to reboot EACH time!
  10. Glider
    Glider /dev/null
    2 Aug 2005
    VMWare is a virtual PC emulator, and the VMWare player is free (and quite lightweight)
  11. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    downloading vmware player now!
  12. Glider
    Glider /dev/null
    2 Aug 2005
    I tried installing my gentoo system there first... you need another tool to create the virtual drives... but I'll google the guide I had for you, gimme a sec
    EDIT: This is the guide I used.
    You need QEMU (also freeware, link on site from guide) and create a virtual disk image (it's a file on your HD). Like this:
    Code:
    qemu-img.exe create -f vmdk c:\vmware\debian.vmdk 10G
    Whereis vdmk the type, c:\... the location and 10G the max size...
    Then you have to make a file (in notepad) with this as content (adapt where nececarry); Filename has to be XXX.vmx
    Code:
    config.version = "8"
    virtualHW.version = "3"
    memsize = "256" [B]<-- Amount of RAM allocated to virtual PC[/B]
    ide0:0.present = "TRUE"
    ide0:0.fileName = "debian.vmdk"  [B]<-- name of the virtual image[/B]
    ide1:0.present = "TRUE"
    ide1:0.fileName = "auto detect"
    ide1:0.deviceType = "cdrom-raw"
    floppy0.fileName = "A:"
    ethernet0.present = "TRUE"
    ethernet0.connectionType = "nat"
    usb.present = "TRUE"
    sound.present = "TRUE"
    sound.virtualDev = "es1371"
    displayName = "Debian Sarge"
    guestOS = "other26xlinux"
    nvram = "debian.nvram" [B]<-- name of the virtual ramdisk[/B]
    scsi0:0.redo = ""
    ethernet0.addressType = "generated"
    uuid.location = "56 4d 4a 15 2a 3f 49 70-03 c9 82 f3 02 82 dc 4c"
    uuid.bios = "56 4d 4a 15 2a 3f 49 70-03 c9 82 f3 02 82 dc 4c"
    ide1:0.autodetect = "TRUE"
    ethernet0.generatedAddress = "00:0c:29:82:dc:4c"
    ethernet0.generatedAddressOffset = "0"
    checkpoint.vmState = "debian.vmss" [B]<-- you can clear this IIRC, otherwise the file where resume info is stored[/B]
    tools.remindInstall = "TRUE"
    ide0:0.redo = ""
    It might need a bit of fiddleing around, but you'll get it ;)
  13. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    hey glider
    well i followed that link (its in a chinese language! lol) i managed to download qemu, but dont quite know what to do with it!
    how/where do i type that line?
    thank you!
  14. horse
    horse What's a Dremel?
    15 Nov 2002
    Creating VMWare Images
    I've been looking at creating Virtual Machines for Windows to try out Live CD's and installs of various OS's
    I found some help here
    there are some sample disk images there, i also found a suitable machine for installing XP or other Windows (cannot remember where though)
    Here is a VM for running live CD's without installing anything
    More inf for creating blank VM's
    Here and here
  15. Cabe
    Cabe What's a Dremel?
    14 May 2002
  16. Zidane
    Zidane What's a Dremel?
    27 Apr 2004
    ok, i'm late to the party, but folks, i am *amazed* nobody here has suggested http://www.easyvmx.com/ for the virtual machine setups!
    i use it all the time when i just need a quick blank machine, it creates the virtual machine files, and the hard-drives, and bundles them up in a nice shiny .zip for you :) if you want to fiddle with the options you can configure just about anything you like.
  17. bender386
    bender386 What's a Dremel?
    5 Jan 2006
    get vmware server its free and can make the virtual machines.
  18. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    USB Keys are treated as hard disks unless otherwise expressively formatted. Make your key have the #1 spot in hard disk boot priority, and see what happens.
