Linux Linux & Gaming
Discussion in 'Software' started by 1e8o, 24 Nov 2005.
  1. 1e8o
    1e8o What's a Dremel?
    13 Oct 2005
    I want a linux OS that can run windows games.
    Do you know wich one?
    Thanx already for the replies.
    PS: I have bought a playstation 2 for € 7.5 and i want to have linux on that one too(does anyone have some experiance with it?)
    Grtz and mod on
  2. JonDixon
    JonDixon Decking is the new modding
    12 Mar 2002
    Linux cannot run windows games.
    You can install Wine which is a Windows emulator on Linux or there is Cedega. I have not used these myself. From what I have heard though, its not worth the hassle as the games dont run as well.
    You are best creating a second partition and turning your PC into a dual boot.
  3. trigger
    trigger Procrastinator
    22 Mar 2004
    Some more recent games have linux clients, allowing you to run the games your have bought under Linux. I haven't used them myself, but am under the impression they aren't very easy to set up.
  4. BBurger
    BBurger What's a Dremel?
    7 Apr 2005
    There are Linux-native games - Enemy Territory & America's Army are both free downloads and easy to install; I gather there's a Linux-native Quake4, too.
    I haven't messed with the whole WINE/Cedega side yet - I have read that it has trouble with the latest DirectX stuff, though...
  5. Go4t
    Go4t i
    13 Dec 2003
    wine has really improved over what it was but cedega is kinda going downhill
    another suggestion for dual booting
  6. simon w
    simon w What's a Dremel?
    3 Nov 2003
    UT2k3 installation:
    Run graphical installer,
    Hit next a few times,
    Run executable file,
    Start fragging
    What could be harder :)
  7. 1e8o
    13 Oct 2005
    Wich LINUX version is that?
  8. Go4t
    Go4t i
    13 Dec 2003
    any of them
  9. lcdguy
    lcdguy Minimodder
    25 May 2004
    bascially if you A don't want a dual boot and want windows games to run on Linux you need wither Wine (i don't recommend it) or Cedega. You have to pay for cedega unless you want to go through the hassle of compiling and configuring a CVS build of it. After that it's a batter of running the cedega program on the windows installation file. it should then work, but it is far from perfect. If it were me i would setup a dual boot system as this would provide the most compatability.
    Just install windows first then install any flvor of linux that you like. When you feel the urge to kill something just boot into windows and your laughing. Other than that your limited to the games with native linux version such as UT2K4, RTCW:ET, etc. I have tried it before and it usually works but for the best performance use a dual boot and save your self the hassle. :)
    Personally i prefer WinXP Pro and Ubuntu or Suse 10.
  10. 1e8o
    13 Oct 2005
    I think i'm going for that. thanx
  11. Confused Fishcake
    Confused Fishcake Minimodder
    25 Sep 2005
    What I have done, is slipstreamed all of the xp updates using nLite, and got rid of everything I don't need (no wmp, no help files, no bluetooth) I got it to boot in 15 seconds, and everything ran super-fast. Alternatively, try the free vmware player, which installs xp to a disk file, works really well for games, I found only about a 10% loss in performance.
  12. lcdguy
    lcdguy Minimodder
    25 May 2004
    or just play linux ports of games like RTCW: ET or UT2004
  13. Colonel Sanders
    Colonel Sanders Minimodder
    25 Jun 2002
    Hate to hijack this thread (but I don't want to start a whole new thread. . .)
    I recently purchased UT 2004, how can I install this on Ubuntu Linux? Do I need to download a file, or are the needed files already on the CDs?
    L J
  14. simon w
    3 Nov 2003
    I bet that you haven't even tried to install it have you?
  15. lcdguy
    lcdguy Minimodder
    25 May 2004
    i am not sure as the only copy i have had is the dvd version which comes with the linux port so i would have no idea on the cd version. But it's probably a Shell Script that needs to be run.
  16. Go4t
    Go4t i
    13 Dec 2003
    look on the first cd
    sh /mnt/cdrom/Linux-installer.sh
    or however you want to do it
  17. Colonel Sanders
    25 Jun 2002
    Nope, haven't tried yet. Thanks for the constructive, usefull reply. :rolleyes:
    Will try what go4t said. Thanks!
    L J
  18. simon w
    3 Nov 2003
    It's just a little annoying when people ask for answers to questions that they haven't even bothered to try and answer for themselves. A quick google search will find the answer and iirc there's even a readme file on the third CD.
  19. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    I suggest you go with Debian, there is nothing different about this distro that makes games play esier, but it's a nice distro anyway..
    If your interested in gaming on Linux, give some of the native games a try, or, explore with dx9wine, which is WINE with Directx9 added, not tried it myself, but i've heard it's not bad performance.
  20. Colonel Sanders
    25 Jun 2002
    While, when I try to run the install script, I cant see signs of anything happening. It doesn't open a terminal window, and I'm not sure what the commands are to launch a script from the terminal. . .
    Right now the PC is in the middle of an update (5.04 to 5.10), would I just need to do "sh linux_installer.sh"?
    L J
