Linux Linux hates me.
Discussion in 'Software' started by Ubermich, 20 Jul 2003.
  1. Ubermich
    Ubermich He did it!
    21 Jun 2002
    Well, I figure I'm going to be a good friend and let my buddy borrow rh7.3 while I try out rh9...
    I turn out to dislike rh9 (still picking up 7.3... didn't need to upgrade)...
    So I get my laptop working again... I need to format it, why not install linux? Crap, I don't have rh7.3... crap, I don't have any more CDs... Alright alright, I'll install rh9... what? CD2 is destroyed? Crap. Crap, I can't find Gentoo... Ah well, I'll try my luck with a debian install... What? The checksum fails? Crap. *rummages about* Ah! Here it is! WHAT!? This checksum fails too!? CRAP!
    So I have to settle for the only thing that will "install"... mandrake 8.2 :grr:
    5 OSs
    1 AWOL
    3 Destroyed
    1 Rubbish
    Total: Either linux or my CDs hate me.
    :sigh:
    Edit: Any idea why it's making run the network config (in harddrake) every time I boot up? Like it doesn't feel the need to remember the fact that the only thing I use it for is to get online...
  2. Kargin
    Kargin Overdose . . .
    18 Sep 2002
    Make sure you told Mandick to save your settings.
    The option should be in neat somewhere.
  3. Ubermich
    Ubermich He did it!
    21 Jun 2002
    How do I get to neat again? I've been using "draknet" in "harddrake" and it's been working, just not remembering... :blah:
  4. Kargin
    18 Sep 2002
    Grab a console, type neat.
    You'll need a GUI for it to work, if you don't have access to one, your going to have to stick to ifconfig.
  5. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    crap, thats alot of crappy craps in one post :D
    CRAP!
    ;) :hehe:
  6. Kargin
    18 Sep 2002
    I shiny ray of hope as usual I see. :D
  7. Ubermich
    Ubermich He did it!
    21 Jun 2002
    bash: neat: command not found
    It's stupid. It only takes a couple minutes (even on this slow pos), but I don't see why I should have to go into harddrake every time I boot...
    Crap. :brrr:
    Edit: Is there any way to install GTK without freetype? I can't seem to get the make install to work properly (tells me "error 2" but doens't explain what that error is and I'm too lazy to look for logs) I'd really like to get xmms installed but it whines about GTK, which whines about glib, pango, ect, which whine about fontconfig, which whines about freetype... So is there a way around this??
  8. Joel
    Joel What's a Dremel?
    9 May 2002
    xmms should be on by default, if not, go to the mandpack or whatever the hell the rpm manager is called and search for xmms, then choose all the options and it should install everything you need
  9. Ubermich
    Ubermich He did it!
    21 Jun 2002
    there's an Add/remove programs, but there's no server info so it can't connect to find rpms to d/l and install... :confused:
  10. Joel
    9 May 2002
    cant you just use the disks?
  11. Ubermich
    Ubermich He did it!
    21 Jun 2002
    No go. The mandrake software manager won't let me define any sources (tells me there's an error, but doesn't say what or why) and if I try going straight to the rpm on the CD it either A) tells me the package is already installed (gaim and freetype, neither of which are installed, at least not properly) or it's a wrong filetype :grr:
    Neither CD has a package for xmms though...
  12. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    Try upgrading to mandrake 9.1
    I have had it running on my main rig(see sig), a k6-350 with 64 megs of ram, a p166 with 32 megs of ram. All worked fine. everything.
    I even have xmms installed no prob, not a darn thing I hate about it.
    http://www.linuxiso.org has a bunch of distros and checksums for ya. Average spped for me downloadin off them was over 20k/s though.
  13. Ubermich
    Ubermich He did it!
    21 Jun 2002
    :sigh:
  14. Kargin
    18 Sep 2002
    That's not the real reason not to upgrade.
    What about just re-installing teh entire damned thing again, jsut install every goddamn non server package it has.
    Or go to your friend's house, beat him senseless and take your 7.3 CDs back. or go to the store and buy a ten pack.
    Your fighting with Mandrake again, you know what happened last time. Well now it's happening again.
  15. Ubermich
    Ubermich He did it!
    21 Jun 2002
    First of all, after rummaging through the CDs I don't see any sign of xmms.
    Second, my friend is supposed to come by tonight with my 7.3 CDs. If he doesn't I will proceed to beat him senseless.
    Third, I'm too poor to buy CDs.
    And yes, I know better than to try with mandrake, but alas that was all I had :sigh:
  16. Kargin
    18 Sep 2002
    That's almost as good as when my friend lost his /boot partition.
  17. Ubermich
    Ubermich He did it!
    21 Jun 2002
    Come look at my CDs! Out of all the RPMs there's no xmms. xine, wine, every kind of useless networking monitor program I could never need, but no xmms.
    **** you mandrake. :grr:
  18. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    <sarcastic remark>
    want me to fix it...
    </sarcastic remark>
    I am runin mandrake on 3 systems, and all is good, but it is 9.1
    oh, and get some beating in there for me too
  19. Kargin
    18 Sep 2002
    That is so hitting the sig. [​IMG] This thread gets funnier with every post.
  20. Ubermich
    Ubermich He did it!
    21 Jun 2002
    I'm glad you're amused.
    /me throws laptop out window
