Portable Linx 7/8/10 Owners Thread
Discussion in 'Hardware' started by Gareth Halfacree, 16 Dec 2014.
  1. Qazax
    Qazax Fap fap fap
    20 Aug 2012
    I really hope so, I am enjoying using windows 8 on the small touch screen, I imagine windows 10 will be even better.
  2. sonicgroove
    sonicgroove Radical Atheist
    16 Mar 2011
    Has no one managed to get the front camera working then?
  3. tyepye
    tyepye Minimodder
    20 Dec 2010
    my front camera works fine as a webcam
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    just tell whatever webcam software your using which camera to use
  5. sonicgroove
    16 Mar 2011
    It doesn't have any webcam software built in anywhere?
  6. Byron C
    Byron C AKA “Sticky Equilibrium” on weekends
    12 Apr 2002
    The bundled "Camera" app seems to use my front camera just fine.
    Also works fine with Skype.
  7. MadGinga
    MadGinga oooh whats this do?
    19 Mar 2009
    arghhh my eyes! they burn! ;)
  8. Byron C
    12 Apr 2002
    ...Little harsh...?
    :p
  9. MadGinga
    19 Mar 2009
    It was like this...
    ...honest! ;) :D
  10. RichCreedy
    24 Apr 2009
    one thing I can tell you, is be very careful when playing in the bios of the linx tablets, mine is currently a brick, with at the moment no way to recover, will be phoning linxtablets to find out if they have any ideas.
    don't ask which settings I changed, cos I cant remember
  11. Big Elf
    23 Apr 2009
    Can't you get into the BIOS holding down the the Power Button and Volume+ keys?
  12. modd1uk
    modd1uk Multimodder
    4 Sep 2006
  13. Domestic_ginger
    Domestic_ginger What's a Dremel?
    16 Mar 2010
    My son dropped my 10" forcing the power button into the chassis. Quick Google showed if you jamb your finger nail into the seem and run it round it comes apart.
    The power and volume buttons fell out, taping them in place from the outside and putting it back together worked for me. Works fine again.
  14. RichCreedy
    24 Apr 2009
    nope, no button combination works
  15. David
    7 Apr 2009
    IIRC, you press and hold the power and vol+ buttons until the Linx logo appears and release before the circling dots appear.
  16. RichCreedy
    24 Apr 2009
    unfortunately the linx logo never appears, it is a permanently off screen, as in it isn't even registering the power button being pressed
  17. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    if there is a bios there will be a battery somewhere - have you tried taking it to bits and taking all the power sources off it in a bid to clear the cmos? (clutching at straws, I don't have a linx tablet but thinking about it like a computer - maybe a mistake!)
  18. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Be careful when playing around with the BIOS - it seems that there is a setting that bricks the device with no way of recovering (no CMOS battery - at the moment, the only suggestion is to let the battery drain completely, but that could take weeks without the tablet being on...).
    More here - sadly nobody can remember what setting they changed :sigh:
  19. Big Elf
    23 Apr 2009
    It's a Li-on battery so waiting for it to drain fully enough for the BIOS to reset could take some years. Taking it apart and disconnecting the battery would be the quickest way. I've seen mention of running a guitar plectrum or thumbnail around the seam is enough to separate the front and back.
  20. RichCreedy
    24 Apr 2009
    sorry been away for a couple of days, before I dismantle it, i'm going to ring the number on the linx tablet website, and see what they say, if I have no joy with them, will take it apart and have a play
