if made some sketches with Sketchup this is my second mod and i hope you will like it plz give me some suggestions or tell if you like the dessing (is this spelled correctly)
all I get is the little red X for pictures. It might be on my side but I have tried refreshing the page three times now.
Okay, I can see one of the pics now. The other worked with the link. Looks good! You might want to have this moved over to the modding forum. From experience this post will not last very long in the Project Logs forum.
The logo your are using is the logo of the software house 'Lionhead' founded by Peter Molyneux, the creators of Black and White.
And to Modding it goes. Send me an email when you have 'in progress' pictures and I'll move it back. Thanks *n
yes it is sketchup 3.0.99 for students i will take some photo's when i'm done does anyone where you can buy a "diamant cutter" for the dremel it is very strong and ideal for cutting steel otherwise i have to use the normal tools
If you are talking about the diamond tipped cutting disc, they are designed to cut glass and will not cut metal.
i dont mean that in dutch it is "diamantslijpschijf" but i dont know what it is in english i will look it up
Can't speak for cutting ones as much but I use diamond discs all the time for finishing rough edges. They do cut metal but I kept cutting through mandrels as much as anything, so I stick to normal ones for that.
