Case Mod - In Progress Liqourice, 11th of August
Discussion in 'Project Logs' started by nepheloco, 11 Aug 2009.
  1. nepheloco
    nepheloco New Member
    10 Dec 2007
    Hi,
    I started this project a long time ago, a year or something. It's almost finished, dvd-writer's front cover still needs to be painted.
    Hope you like it. :worried:
    Used my old hardware:
    • XP2000+
    • 768Mb PC2700
    • R9600
    • 320Gb Seagate Barracuda 7200.10
    • Corsair VX450
    Made a quick sketch:
    Here you can see what the case originally looked like (started smoothing it, but it looked a bit dull so I dumped that idea):
    Had some blue acrylic lying around, used it to build up the air intake and cover the 3,25" bay.
    The white gooey stuff is a two part epoxy based glue, you can also see the white 1" PVC pipe that I cut in half to make the inside of the duct:
    Then I raised the sides of the 5,25" bay so that the optical drive would stick out:
    Then I used some body filler and sanded it down to make it some nice curves :rolleyes: :
    Started on the side window:
    [​IMG][​IMG][​IMG]
    And again some filler:
    Then I cut a hole to the other side to show the green PCB :hehe: :
    Some more bondo and sanding pads:
    And then I sent it off to a paint shop (it's great when someone in the family makes a living painting cars :D):
    I like this shot a lot :clap::
    On/off button and hdd-led:
    Quite happy with the results :p.
    It isn't perfect but it gave me a load of new ideas. :thumb:
    For my next project I'll do a scratch build that would become my new main computer for CAD and rendering. I think there's a sketch somewhere in my notebooks, only need to find it and take a picture of it.
    Although first I have to work on my glassfiber skills that are non-exsistent at the moment :worried:. Is someone familiar with that and could give me some tips? :geek:
    What's a good material to start building the positive?
    (if I used some odd expressions or grammar, then be free to comment them, I'd really appreciate it :),haven't had any english practise for a few years)
    jhanlon303, The boy 4rm oz and Javerh like this.
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    :clap:
    Love it
  3. The boy 4rm oz
    10 Apr 2008
    That is an awesome transformation, very nice bondo work. +rep
  4. nepheloco
    10 Dec 2007
    Little bit of searching and I managed to find a rough sketch :clap::
    But that's not going to happen in the near future, I might make the outer shell this year, but not more. :rolleyes:
    More important things first, like my studies and close ones, who really matter. :)
  5. Cheapskate
    13 May 2007
    Nice!! This is a perfect example of how an evil beige brick can become something attractive.:thumb:
  6. mr.sh
    mr.sh FEAR
    31 Jul 2009
    Simple but very nice!!!!
  7. Fozzy
    Fozzy New Member
    25 Jan 2005
    wow did not expect that. the difference between the first picture and the last...wow. Great job man.
  8. Jelle46
    Jelle46 Belgian freedom
    14 Feb 2009
    I like the total black look, great!
  9. jhanlon303
    7 Sep 2006
    From this:
    to
    this
    :jawdrop:
    Much to be admired for your skill and design work.
    john
    +rep for skillz
  10. The_Gnu
    The_Gnu 8-bit addict
    12 Sep 2005
    Nice one. Like the bondo work and the shiny paintjobb.
    /Gnu
  11. mercerman318
    mercerman318 New Member
    12 Aug 2009
    That is a pretty clean case, i love the final look, what kind of case was that originally?
  12. Eurofix
    Eurofix New Member
    13 May 2008
    WOW! One of the best make overs eva!
  13. nepheloco
    10 Dec 2007
    It says Fuji... under the sloppy bondowork on the first picture. Can't remember if it was Fujitsu-Siemens or just Fujitsu.
    Was browsing through a local hardware forum's used hardware section and stumbled on it.
    All the sides were plastic, motherboard was upside down and it was a old which meant it's built like a tank. :thumb:
  14. Kyor
    Kyor A Visitor
    28 Jul 2009
    Very nice work :eek:
    And especialy nice job on the bondo job ;)
  15. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    thats wicked! nice transformation.
  16. wbdog206
    wbdog206 not me
    15 Jan 2007
    Sweet!
    The body work and paint look great.
  17. [+]EXEcuteER[+]
    [+]EXEcuteER[+] Cracking up the Plex
    13 Aug 2009
    the glossy surface looks very clean. how often was that painted?
  18. nepheloco
    10 Dec 2007
    One coat.
    First it was painted with a dark gray color with a small flake in it, but it didn't turn out good - too thick and some cracks came up on the left panel. Different materials (acrylic, filler, plastic and metal) didn't expand the same in the oven. So I sanded it down, sprayed on a heavy coat of primer, had it painted again and dried without baking.
    Few pics of the original color (didn't adjust the lightning so it has a gold hue to it):
    And in the last picture you can see a slot between the front and side panel, that's a smartcard reader:
  19. zanettii
    zanettii New Member
    11 Dec 2008
    A LCD or something in the front have been awesome! Nice project though : )
