Modding Liquid epoxy or super glue?
Discussion in 'Modding' started by Emon, 9 Aug 2004.
  1. Emon
    Emon What's a Dremel?
    14 Jun 2004
    Does anyone know of an epoxy or super glue which is a liquid? It would have to be about syrup-thick, thin enough to say, flow between microfins on a heatsink for example. It also must bond very well to metal, not break down with age or be affected by water/moisture. Epoxy seems just about perfect, but I have no idea if a liquid version exists, or of any way to liquify it during cure time without significantly weakening the bond. There are polyurethane glues like Gorilla Glue, but most people say they don't bond well to metal, and foam up, which is not what I want, as I am not wood working.
    Any ideas here? The only one I had was using a hard super glue that worked on solvent evaporation, then mixing some of the glue with the solvent to thin it up. With ample drying time, it should harden to the same rock solid state with the same bond strength (or close enough) as if it was plain, thick super glue.
  2. toyomatt84
    toyomatt84 What's a Dremel?
    1 Jun 2004
    Almost all epoxies are liquid 2-part. You should go to a hardware store. They bond to metal very well.
  3. Emon
    14 Jun 2004
    Those aren't liquid, they're pastes. But the proper Google query got me results. "Low viscosity epoxy" not "liquid epoxy". :duh:
  4. danmagicman7
    danmagicman7 What's a Dremel?
    11 Jun 2004
    paste?
    epoxy can glue anything together, it should work for almost everything you need.
  5. Emon
    14 Jun 2004
    ...I realize that. If you read my post, you'd know I need to be liquid so that it gets into small cracks and crevices. Every epoxy I've used is thick and doesn't even sag that much, let alone flow into cracks the size of microfins on a heatsink.
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Google " casting epoxy resin ", should give you some sources for the low-viscosity mixes. IIRC some of the stuff used for moulding fibre-glass things is paintable.
  7. Emon
    14 Jun 2004
    Thanks cpemma, that's quite helpful.
  8. chalk_mark
    chalk_mark What's a Dremel?
    8 Aug 2004
    devcon www.devcon.com
    They make adhesives that will join anything. not sure where you could get it in your area, but do what I have done... ask nice for an engineering sample. :D
    At work we have used some of their stuff to mount those little reflectors you see on the highway pavement. wicked glue.
  9. wharrad
    wharrad Minimodder
    26 Jul 2003
    Try a model shop - they have Cyno. It's like an ultra-strong supergule. Essentially it's as strong as epoxy (at the right mixture!) and as runny as supergule.
    As an added bonus it comes in either thin (super runny) medium (medium runny) and thick (ok, so I won't teach you to suck eggs :D ).
    Used mainly on radio controlled planes see.
  10. Whisp[TR]
    Whisp[TR] What's a Dremel?
    25 Jan 2004
    I use 5 minute epoxy. the stuff that has 2 sides and you squeeze them out and mixe them. That will stick to metal and such and I have used it on ataching plastic to metal such as in my dice thumbscrew mod. Also it not to thick right away that you can drip it where you want.
  11. Emon
    14 Jun 2004
    wharrad, do you mean Cyano? I did a little Googling and that seems it may good.
    I found epoxy casting resin at a local craft store today, but all they had were huge bottles that were no less than $10, and I need a much smaller amount. I'll check some more model/craft stores or maybe just get some online. I'm not sure about the adhesive strength of those, however, because people usually use it for making small things like plastic knobs or whatever, not as an actual glue. I can still get low viscosity epoxy online at least, and automotive stores may have it.
  12. danmagicman7
    11 Jun 2004
    I use small things such as toothpicks and even cardboard to push epoxy into those small crevices. What application are you using it in? Epoxy will seal small cracks and crevices...
  13. Emon
    14 Jun 2004
    I won't be able to push it in with a toothpick, trust me. It must be at least syrup thin to flow into the cracks on its own.
    But as I said, I have found what I'm looking for, thanks though.
  14. wharrad
    wharrad Minimodder
    26 Jul 2003
    Yeah cyano - that's the stuff.
    Ah, we all make the odd spelling mistake :blah:
