Electronics Lithium ion battery question
Discussion in 'Modding' started by quizz_kid, 16 May 2013.
  1. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Hi guys.
    I have a device driven by 3xAAA batteries but would like to use a rechargable lithium battery instead. I really don´t want to open up the device every now and then changing batteries.
    So, what are my options here?
    I can´t seem to locate a 4.5V Lithium ion battery anywhere.
    Can I use a bigger battery maybe and then have some sort of module that keeps the output voltage around 4.5?
    I´d also like to have some charging/full charge LED indicator.
    Help much appreciated :lol:
    //Quizz
  2. GoodBytes
    20 Jan 2007
    You'll need to build you own circuit.
    You are better off using NiMh rechargeable batteries.
  3. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
    Rachargable NIMH will only be at 4.5v for a very short time once charged.
    A single cell lipo when charged is 4.2v
    Care should be taken when charging though.
  4. GoodBytes
    20 Jan 2007
    It will be 3.6V, and it's plenty. His device probably ACTUALLY consumes 3V.
    If it consumed 4.5v, then rechargeable batteries wont' even works, as they are 1.2v
  5. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Hmm... The device uses regular AAA so I guess It can work with less than 4.5V
    Do you have other suggestions?
    I don´t want to open the device everytime the batteries runs out
    EDIT: It would also be great if I could charge the device though USB
  6. Shirty
    18 Apr 1982
    What's the device? :naughty:
  7. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    It's a modified usb controller
  8. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    Li-ion are a real pain.
    Go with NiMh.
  9. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Ok, i might do that.
    Can you explain why Lithiums are such a pain?
    Also, I´ve never used NiMh before. Should I go for an 4.8V(closest I found) battery then maybe?
    And can you add an charge/fully charged indicator somehow?
    //Quizz
  10. Ending Credits
    4 Jan 2008
    I'm by no means an expert (TBH, I know ****all), but Li-ion batteries are very complicated and require constant balancing otherwise they will last a very short time. Fine if you want to buy a pack yourself, but if you want to make a battery of cells or modify them in some way then it's going to be very difficult. NiMH are a bit heavier and suffer from the memory effect (also, I've just read they have quite a high rate of self-discharge) but are simpler and safer.
  11. Tealc
    Tealc What's a Dremel?
    6 Oct 2010
    You can get low self discharge NiMH such as Sanyo Eneloop.
    A 4.8v NiMH will be 4 normal cells in series, which will of course show over 5v when fully charged. If the current of the circuit is low enough you could use a zener diode as a regulator to prevent too much voltage being presented to your device.
    Charging NiMH is much easier than Lithium cells as Lithium cells tend to blow up if not charged properly.
    siliconfanatic likes this.
  12. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thanks for the info! So NiMHs shouldn't be charged unless almost completed?
    How do I know if the current of the circuit is low enough?
    Another thing. Let´s say I have a NiMH 4.8v 220mah battery, would it be possible to charge it from a USB port?
  13. Tealc
    6 Oct 2010
    Ideally you'd have a bit more voltage headroom to charge four cells so the 5v of a USB connection would not be sufficient for four cells in series. It would be ok for charging two in series twice. You still have to be careful that you restrict current as USB current will kill batteries if not turned off once the batteries are fully charged.
    I doubt you need to worry about voltage regulation as devices do allow a range of voltage and half a volt here or there will unlikely be a huge issue. Also if you are only thinking of powering with a 220mAh battery you'd better hope your device doesn't draw much.
    Chargers will ideally be constant current until their voltage rises to a certain point and then switch to contant voltage. You can do both with LM317 but as for how to set a circuit up you'd have to check up on that.
    Using the device while charging could be problematic too.
    220mAh is a very small capacity battery. That's in the region of a 9v PPM battery capacity. 4x AA cells would give >2000mA in comparison.
  14. phenoptix
    phenoptix What's a Dremel?
    16 Aug 2006
