Development Little add/subtract C++ program
Discussion in 'Software' started by Edge102030, 23 Sep 2009.
  1. Edge102030
    Edge102030 Son, i am disappoint.
    21 Aug 2009
    Hi there,
    Was wondering if somebody could help me. I'm trying to learn C++ and i've decided on a (very) simple project to try and expand my knowledge of the syntax/language. I have got this code so far:
    Code:
    // Simple add/subtract CLI program
    #include <iostream>
    using namespace std;
    int subtraction (int a, int b)
    // Subtraction instruction set
    	int r;
    	r=a-b;
    	return (r);
    int addition (int a, int b)
    // Addition instuction set
    	int r;
    	r=a+b;
    	return (r);
    int main ()
    // Main instruction set
    	int z;
    	int y;
    	int a;
    	int b;
    	z = addition (a,b);
    	y = subtraction (a,b);
    	cout << "Please enter an integer: ";
    	cin >> a ;
    	cout << " .\n" <<"Add or subtract?(z/y): ";
    	cin >> ;
    	// Cin above needs a pointer to choose z/y add or subtract, help??
    	cout << "Choose a number to add or subtract: ";
    	cin >> b;
    	cout << "The result is " << ; //Needs to use (r) for return==result from add or subtract
    I was hoping somebody would be able to help me with making this code do what i want, which is enter value a choose add or subtract (z/y) then choose another number to add/sub and display the result with cout.
    Thanks in advance:jawdrop::D
  2. Krikkit
    21 Jan 2003
    So let me get this straight:
    enter a number -> select whether to add or subtract -> enter the number to subtract -> output result
    If so then you could use a case statement for each possibility to access the different subroutines.
    I'd program it for you, but it sounds like homework and you'll learn more if you program it yourself... :p
    Edge102030 likes this.
  3. Edge102030
    21 Aug 2009
    That's right. Would you mind explaining what a case statement is please?
    p.s thanks for replying and editing my post =D +rep
  4. hitman012
    hitman012 Minimodder
    6 May 2005
    There are a couple of problems with your code. First of all, you have this at the start of your program:
    Code:
    z = addition (a,b);
    This will give either zero or a weird number because you haven't initialised (i.e. set to a value) the variables a and b. You want to perform the subtraction after the user has supplied the values for these variables.
    Secondly, it would be more efficient to have a single variable to store the result, rather than using seperate variables for addition or subtraction. That saves you having to decide which to output. Something like this would do the trick (pseudocode - I'm not doing homework for you).
    Code:
    int a, b, result;
    char operation;
    // Get the input data
    get a and b from the user
    get the operation type (addition or subtraction)
    // Now do the addition/subtraction
    if the operation is addition
        result = addition(a, b);
    else if the operation is subtraction
        result = subtraction(a, b);
    // Output the results
    cout << "the result is " << result << endl;
    For switch/case statements, look at the C++ examples on Wikipedia (http://en.wikipedia.org/wiki/Switch_statement) and it should become fairly clear.
    thehippoz and Edge102030 like this.
  5. Edge102030
    21 Aug 2009
    Cheers hitman that makes sense now, dunnno why i didn't think to use if
    p.s thanks for the speedy reply +rep
  6. Edge102030
    21 Aug 2009
    Apologies for double post, but i got it :rock: using your code hitman with my code(for declaration of add/sub actions) it works:hip:.
    Code:
    #include <iostream>
    	int r;
    	r=a-b;
    	return (r);
    	int r;
    	r=a+b;
    	return (r);
    int main ()
    int a, b, result;
    char operation;
    cout << "Enter an integer:" << endl;
    cin >> a;
    cout << "Which operation do you wish to perform? (a = add, s = subtract)" << endl;
    cin >> operation;
    cout << "Enter another integer:" << endl;
    cin >> b;
    if(operation == 'a')
    else if(operation == 's')
    cout << "The result is " << result << endl;
    Thanks alot guys, will check out that wiki, but i also just found this guide:http://www.cplusplus.com/doc/tutorial/ which looks pretty good.
  7. Krikkit
    21 Jan 2003
    cplusplus.com's tutorials are excellent, they really helped me with my uni programming courses.
  8. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
  9. Daedelus
    Daedelus What's a Dremel?
    7 May 2009
    You should always initlialise all variables when declaring them otherwise they are undefined which can cause problems.
    e.g.
    int x = 0;
  10. Von Lazuli
    Von Lazuli I get by fine with a jig-saw.
    23 Oct 2008
    Your subroutines could be optimised a little. At the moment you are creating an additional variable where you don't need one.
    Eg:
    Code:
    int addition(int a, int b)
       return a+b;
    I must admit, I haven't played with C++ much, it does look a lot nicer than C to work with though.
    Laz
  11. Krikkit
    21 Jan 2003
    It's loads better than C to work with tbh - we started with C-only commands in C++ and worked up to more advanced stuff, and it's so much easier to get anything done in ++.
  12. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    tbh it's better practice to introduce the concept of a return value asap. it's a lot nicer when you work with a result value and return that at the end of your code with a single return statement; that way you always have a single entry and exit point, which helps with debugging when your apps get complex.
  13. Unicorn
    25 Jul 2006
    +1. I still have a module on C++, even in year 3 :sigh: (named Software Development III). By now we're just sick looking at it. My degree is called Electronics, Communications & Software engineering, but none of us thought there would be quite so much software development involved.
    By the way what compiler are you all using? And does anyone code for any hardware applications? Our teaching focuses on programming PIC Microprocessors.
  14. Edge102030
    21 Aug 2009
    I'm using Xcode (OS X), i tried using Visual C++ and i really didn't know how to use it properly, for instance the errors in my code found in debugging weren't actually anounced(it just said there are errors). As well as the fact i didn't reall understand how there could be errors in the code that worked in Xcode when tried in Visual.:jawdrop:
  15. Krikkit
    21 Jan 2003
    I have to say the whole compiler thing is a dark art to me - I've never really used anything but the most common program for learning with... Usually a full IDE like Visual Studio or the equivalent (i.e. Borland's Delphi).
    Has anyone heard of the programming language that's basically made up entirely of simple syntaxes? We learnt a bit with it at A-level and I can't remember what it is for the life of me.
  16. Daedelus
    7 May 2009
  17. Scorpsel
    Scorpsel Imaginary Time
    29 Nov 2004
    Not sure what you mean by simple syntaxes but there's always Brainf*ck or Whitespace..
  18. Krikkit
    21 Jan 2003
    Found it: Pascal. :thumb:
