Case Mod - In Progress "Little Angel" - * COMPLETED! - Final pictures pages 20 & 21 *
Discussion in 'Project Logs' started by xSoMBrAx, 8 Oct 2011.
What to do: Black or white tubing!?
  1. Black!
    26 vote(s)
    40.0%
  2. White!
    36 vote(s)
    55.4%
  3. No idea, I hate water cooling!
    3 vote(s)
    4.6%
  1. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    what did it cost ?
    That looks sooo damn sexy :D
  2. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    It cost nothing, I designed it they made it for me ;)
    Contact them for a quote! :)
    I've been doing some wiring for the GPU lately and figuring out how to route them to the PSU's since it's getting very busy down there xD
    I already got my GTX 680's but just recieved one EK block, the other one is on it's way... I rushed after seeing their new design lol :duh::duh::duh:
    I think I will do some sleeving tonight! :)
  3. Mizugetsu
    Mizugetsu What's a Dremel?
    12 Aug 2008
    i think you did the right thing the new Blocks look awful the layout is great but the Circles and the frosting of the the Plexi is Shocking hopefully with all the backlash they've had they will either make Replacement Tops or just go back to the Clear Plexi with no Circles
  4. DarthBeavis
    DarthBeavis What's a Dremel?
    29 Aug 2008
    you realize you are in for problems when the nickle-plating flakes on your EK blocks?
  5. Reconnec7ed
    Reconnec7ed What's a Dremel?
    29 Feb 2012
    And you realise that this issue was way back in 2011 and EK were made aware of it and have corrected the issue?
  6. PabloFunky
    PabloFunky What's a Dremel?
    19 Sep 2010
    I purchased the XSPC blocks for this mobo, incase i decide to buy the mobo one day myself.
    Eks site does show the mosfet block also.
    My xspc block was somewhat bent, god knows how it was bent, unless a forklift or a house fell on it, but i managed to bend back in a vice, to save rmaing.
    So the xspc block may be an option, if you can find stock, as i had the last one from Specialtech.
    looking nice though.
    Also not liking the new csq block design by ek
  7. DarthBeavis
    29 Aug 2008
    not from what I have read. Sidewinders gave some insight NSFW image so do not click if boss is looking ) http://www.realredraider.com/vbulletin/showthread.php?t=58257
  8. DarthBeavis
    29 Aug 2008
  9. Mizugetsu
    12 Aug 2008
    Well i've never had any issue and at certain points I've used tap water with blue food dye in my loops with copper naked block on CPU and nickel 8800gtx With no issues
  10. DarthBeavis
    29 Aug 2008
    what does that have to do with problems with nickle-plating?
  11. Mizugetsu
    12 Aug 2008
    Well everyone says that eks nickel plating is corroded by people who are using ultra pure waters and silver coil descalers is what causes ek nickel to have it's issues I'm just saying if I'm running the dirtiest most ghetto coolant which hasn't been changed in 3 years and my loop still
    Looks fresh and clean what are people putting in the loops ****ing hydrochloric acid here's a tip stop belly aching EK have changed there nickel plating process which can only be only really be tested by people who are running 680 nickel and 680 CSQ blocks for 6+ months.
  12. DarthBeavis
    29 Aug 2008
    no they changed it before then . . .you might try to actually know what you are talking about before commenting
    Video of EK EN vs old way August 2011
    http://www.youtube.com/watch?v=yMHoBBmlljs
    680s launched I March 2012 I think (I was at the NVIDIA launch event)
  13. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Believe me, EK's nickel issues are far from over. They're still seeing new blocks die on XS, and their process isn't any better now-as well as their machining.
    Distilled and silver should have no effect on any block. EK's claim that it does is pure misdirection because the plating does not hold up to any standard depth-US, EU or otherwise for legally being called plated. I've autopsied blocks from them where it peeled off like tissue paper.
    DB wasn't trying to be a jerk-he doesn't want to see you lose this loop six months down the road, which is completely possible. Nor do I for that matter. I lost block, tubing fittings pump and res, and just did get everything blasted out of the rad it was using. Not I heard, or someone posted, I personally lost that. And I don't care to see others get burned like I did.
  14. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    I'm aware of the EK nickel plating problems but I couldn't find any other block that I liked to use for this project.
    Also the Acetal + copper were not available and I wasn't sure about the looks...
    *Fingerscrossed*
  15. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Little update from the HDD's and SSD's rack
    I've added the SATA data cables, by the pictures it looks like it's just one connected but using 90º angled cable I managed to connect all of them without many troubles.
    Side picture to better show you what I mean
    Yes... now all of the wires you see need to be sleeved of course!
    Still trying to decide what pattern to follow but I was thinking Vanilla for the SSD's, black for the caviar blacks and white for the other RAID 1 drives...
  16. DarthBeavis
    29 Aug 2008
    Love the custom power wires (did that on a project without sleeving comes out great).
    For the block: I suggest you have it plated yourself.
  17. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Have it chromed. Swiftech never had any issues on their MCW60-4870 blocks. I have two of them and they still had coolant in them when i bought them used and they are flawless.
  18. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Yes I really like the end result so they are going to stay like that :)
    I've been busy with sleeving, I will show you just a before and after pics... more to come!
    Thanks!
  19. KoSoVaR^
    19 Dec 2010
    I love it ! What did you strap the sleeved cables with ?
  20. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Thanks!
    I used nylon thread and wire lacing to have the wires to stay like that.
    More pics later.
