Case Mod - In Progress "Little Angel" - * COMPLETED! - Final pictures pages 20 & 21 *
Discussion in 'Project Logs' started by xSoMBrAx, 8 Oct 2011.
What to do: Black or white tubing!?
  1. Black!
    26 vote(s)
    40.0%
  2. White!
    36 vote(s)
    55.4%
  3. No idea, I hate water cooling!
    3 vote(s)
    4.6%
  1. Squigly
    Squigly MODfiend.. ~twitch~
    20 May 2012
    If it has to be black or white i would say black, ties in better.. but i am +1 for the clear with gold coolant, its a no brainer!
  2. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
    I like the white with that case.
    Can't believe it took me so long to find this thread. Your build looks so much more professional than my LD build :)
  3. xSoMBrAx
    xSoMBrAx Member
    18 May 2011
    Thanks everybody for the feedback...
    I've been doing some tests with tubing and the leds I'm going to use and with that combination the black one is just perfect...
    I will post updates soon and will try to take some pics with leds on :)
    Thank you again for following this worklog... it encourages me to finish this build soon! :)
  4. krussellusaf
    krussellusaf Member
    28 Jun 2012
    Can't wait to see more progress. Everything you do inspires me to do more!
  5. xSoMBrAx
    xSoMBrAx Member
    18 May 2011
    Thank you :)
    Minor update!
    I just realized that to black tubing to work white led should be used to give some ambient light to the interior of the case.
    I will use this led strips mounted on a white PCB
    I will also use this alu profile so I can slide in the PCB (50~60cm) and give a nice touch to the whole setup.
    Led, profile and the cover, all together!
    I'm waiting for some stuff that I think I will recieve today, I will try to update tonight or tomorrow...
    Also I'm going to finish the setup of the led (wiring + sleeving) and connect them to the Aquaero 5
  6. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Looks good. Very nice LED strip and the mounting profile is very nice to look at.
  7. xSoMBrAx
    xSoMBrAx Member
    18 May 2011
    So finally leds are installed and wires sleeved.
    Let me show you the result
    One of the strips was attached to the top of the case.
    This is a smaller version of the top bar, without the alu profile, that I installed at the back of where the hard disks are installed.
    You can see the light but no the led strip!
    From far...
    Zoomed!
  8. barfastic
    barfastic New Member
    21 Feb 2011
    nice lighting effect sombra!
    Your project is progressing very very nicely! :D
  9. krussellusaf
    krussellusaf Member
    28 Jun 2012
    The Mr. Miyagi of modding!
  10. Nutman
    21 Oct 2008
    Awesome!
  11. Asouter
    Asouter --------
    18 Jan 2012
    It's a toughy black or white ? I see you have gone with the black tubing using the LED's to pick out the tubing...I notice that the black sleeving on the atx cable contrasts nicely against the white interior, was thinking the white tubing would contrast against the black mobo. I know it's the obvious choice but that's my 2 pennies worth. + for the clear tubing and gold coolant :D
    I'm not being very helpful am I ? :hehe:
  12. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    (Starts chanting) WE WANT GOLD, WE WANT GOLD! :lol:
    I have a sneaky suspicion that no matter what you choose, it will look awesome! :)
    I'd just love to see how clear tubing and Mayhem Gold would look! :)
  13. xSoMBrAx
    xSoMBrAx Member
    18 May 2011
    Thanks!
    NO! But maybe it's worth to try since I have a lot of white tubing...
    I'm not a fan of putting dyes into the loop and I was 99.99% sure that I will never use that but... you never know..
    Maybe for version 1.1 :D
    As said will give white a try but I think it's going to look too much white and also the gold fittings are not going to look good at all...
    The problem I'm having with the black tubing is that the wall of the tubing is not that thick compared to the white and I have to be really careful
  14. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Have you seen this ;)?
  15. r1sKas
    r1sKas Orange or White? Lets mod!
    22 Jan 2011
    Take white on those tubes!
  16. xSoMBrAx
    xSoMBrAx Member
    18 May 2011
    First time I see that!
    Looks great but I think you will preffer my "pumping station", stay tuned :D
    I will try both... not sure about the contrast against golden fittings though!
    Finally, bullets are GONE for ever (hopefully!)
    I'm really happy with my new motherboard block :)
    I'm very happy with the overall quality BUT I think the packaging was not good enough, you can see some damage on the mosfet block.... but it could be worse!
    Can't wait to put some nice fittings and start planing the loop :D
    More pics soon!
  17. KoSoVaR^
    19 Dec 2010
    Bitspower makes awsome blocks, i Just got the Summit Intel CPU Block and my fittings...it looks so damn sexy ;)
    This is btw an sneakpeak picture from my new project, i will make an buildlog as soon as have everything :)
    You can see more on my Facebook page
  18. jamsand
    jamsand Well-Known Member
    21 May 2011
    ^totally not a plug -.- loving those ram blocks looking good!
  19. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Black and Gold.....whats not to like?
    Polished copper pipe would of looked good tho....
    I like,im a proud V8 owner also! :clap:
  20. xSoMBrAx
    xSoMBrAx Member
    18 May 2011
    I like BP also <3!
    It is a great product!
    I have no idea how to make those pipes that's why I had to go with tubing but I know your work I'm following your log aswell and I posted already there too :)
