Case Mod - In Progress "Little Angel" - * COMPLETED! - Final pictures pages 20 & 21 *
Discussion in 'Project Logs' started by xSoMBrAx, 8 Oct 2011.
What to do: Black or white tubing!?
  1. Black!
    26 vote(s)
    40.0%
  2. White!
    36 vote(s)
    55.4%
  3. No idea, I hate water cooling!
    3 vote(s)
    4.6%
  1. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    If you ever fancy a change,i would be more than willing to video guide it for you :thumb:...i should make a video anyway,i keep getting asked how to do it....:idea:
  2. xSoMBrAx
    xSoMBrAx Member
    18 May 2011
    Let me know when you poste that video! :)
    I've already installed to blocks to the motherboard!
    Fittings added too, enjoy!
    Still planing the tubing route but I think I got it already... will update with final picture!
    I've shorten some tubes already, this was just for testing.
  3. barfastic
    barfastic New Member
    21 Feb 2011
    thats lookin sexy as hell!
  4. Mizugetsu
    Mizugetsu New Member
    12 Aug 2008
    is it just me or does silver/grey tubing sound rather interesting after that last pic?
  5. xSoMBrAx
    xSoMBrAx Member
    18 May 2011
    Thank you!
    I'm not sure... check out the final setup and let me know what you think.
    Thanks!
  6. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Pretty clean :)
  7. xSoMBrAx
    xSoMBrAx Member
    18 May 2011
    Thanks! :)
    I did some work tonight, not the best picture so please forgive me!
    I was planing how to connect the top radiator to the Aquaero 5 since I bought the waterblock aswell... Loop is getting busy!
    I couldnt just "throw" a pipe down because other devices will interfere with the fittings / tubing so I had to reroute the loop outside the 5 1/2 "cage"
    My friend Michael inspired me with his holes for wire management! Thank you barfastic :)
    It was really hard to measure from the inside to make it a perfect straight "pipe"...
    Measurement was done from the inside but the hole must be done from the other side because my drill is way too big to do it from the inside!
    DONE, fingers crossed...
    Outside looks good, not sure if I was accurate enough...
    Just perfect!
    Very happy with the result!
    Now need to repeat the process at the Aquaero 5 bay...
    Done!
    Now I need to link the holes, I will build a bitspower bridge! :D:D
    More tomorrow :)
  8. cmd_
    cmd_ New Member
    4 Jul 2008
    Hey dude, i'm glad to see more spaniards here. I haven't see you before, maybe I know you from some lanparty? How old are you boy? I'm being a old dog... I don't know anything about new generations.
    I like your project, you have some interesting ideas and a lot of attention to details :thumb:
  9. xSoMBrAx
    xSoMBrAx Member
    18 May 2011
    Hello cmd_!
    I don't know you, but I have seen your work in the past!
    I'm 29 and I haven't been to any lanpartys :)
    Thank you for the nice words!
    I love your work :)
  10. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Wonderful progress!
  11. mybadomen
    mybadomen New Member
    19 Jan 2012
    Very Impressive Mate !!!
    MybadOmen
  12. Telefonskaft
    Telefonskaft New Member
    31 May 2011
    Looks really good! I for one really like the black tubing :)
  13. xSoMBrAx
    xSoMBrAx Member
    18 May 2011
    Thank you everyone for the nice comments!
    I've installed the bitspower bridge... let me show you!
    Some fittings to make the bridge
    All together... now into the case
    Perfect fit!
    Now I need to link the bridge with the Aquaero 5...
    Will try to do that tomorrow! :)
  14. Furball Zen
    25 Jan 2012
    No crystal link?
  15. krussellusaf
    krussellusaf Member
    28 Jun 2012
    I can't wait for tomorrow!
  16. barfastic
    21 Feb 2011
    Heya sombra!
    Im glad i inspired you, but how will the flow be to the waterblock.... Wont you ruin the rest of the loops flow?
  17. xSoMBrAx
    xSoMBrAx Member
    18 May 2011
    I would only use Crystal Link if I was going to use dye but I'm not... Also I don't have any of the crystal links or fittings so that would be another order and moreee waiting hehe.
    Maybe a future revision will have dye + crystal links for instance :)
    I feel ok doing the loop this way since I'm not using many 90º adapters... just 5 for the whole loop and I've seen some tests and the restriction is not an issue at all...
  18. barfastic
    21 Feb 2011
    oh, i didnt mean the 90's, i meant that you are using the "bottom" port of the radiator... What about on the other side? do u have both ports in use?
  19. xSoMBrAx
    xSoMBrAx Member
    18 May 2011
    Oh got you now.
    No, I'm not using any of the other ports, there is only 1 inlet and 1 outlet connected to each radiator :)
  20. Ulti
    Ulti Poor student
    20 Jun 2012
    Just went through the whole thread in one go, definitely worth the read! Thank you for sharing your amazing build. I'm a bit sad that you didn't manage to finish though but I'm loving the progress, shouldn't be too far from the finishing line now right?
    Pure overkill though! But I don't think I've seen a system that isn't overkill on here yet haha.
