Case Mod - In Progress "Little Angel" - * COMPLETED! - Final pictures pages 20 & 21 *
Discussion in 'Project Logs' started by xSoMBrAx, 8 Oct 2011.
What to do: Black or white tubing!?
  1. Black!
    26 vote(s)
    40.0%
  2. White!
    36 vote(s)
    55.4%
  3. No idea, I hate water cooling!
    3 vote(s)
    4.6%
  1. Johnny71
    Johnny71 What's a Dremel?
    6 Jun 2012
    Who did the stickers for you ?:D
    Nice work bud:)
  2. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Thank you my friend, hopefully the build will be finishe dsoon... at least is what I think!
    Update time:
    I've managed to hardpipe with bitspower fittings from the wall adapters to the Aquaero 5 waterblock
    Bitspower puzzles!
    Done!
    Finally I had to use some extra bitspower fittings as "spacers" because It was impossible to use 19/13 fittings (they were way too big and the waterblock screws were intefering)
    I think some crystal link to finish the connection would look good, but since I'm not using any dye I will stick to fitting + tubing to close the loop (from Aquaero 5 to the reservoir)
    Squigly likes this.
  3. krussellusaf
    krussellusaf What's a Dremel?
    28 Jun 2012
    Modding magician. Everything you post is beautiful!
  4. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Thank you my friend.
    I had to change the loop a bit because the black tubing was collapsing.
    I'm having troubles to link the RAM blocks with the CPU and because of that I had to use longer tubes so different route :)
    I will try to post some pic later!
  5. krussellusaf
    28 Jun 2012
    I assume that means you are trying to hard pipe to the RAM? No chance you will flex pipe it?
  6. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    No, I will still use the black tubing, but I will have to connect them in a different way...
    It will not look that "pretty" but the tube will not collapse...
  7. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Lovely stuff.
    I am getting an Aquaero 5 XT, too, with the watercooling block aswell. Eager to see how much more ooomph it will bring to the game.
  8. hairyknacker
    hairyknacker Minimodder
    25 Jan 2012
    'Som
    What size of bitspower fittings did you use for the Aquaero block? I've just ordered me one and not sure of the fitting sizes to order
    BTW- magnificent work as ever
  9. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Waterblock for the AQ5 is a must because it get very hot, the bad part is how to integrate it into the loop hehe
    You can't use 19 / 13 fittings (1/2 - 3/4) because they are not going to fit, you need to use some extensors.
  10. hairyknacker
    25 Jan 2012
    so is it the 1/4" long ones to fit the block then attach to usual fittings? I only have 19/13 fittings on my stuff so bit unsure of which ones to get
  11. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    You could use some spacer for the inlet or outlet of the block and use a 45º rotary adapter for example on the other side, that would also work.
    If you try to fit 2 x 19/13 fittings together then they are going to touch the bolts of the block and it's not possible to fit them.
  12. hairyknacker
    25 Jan 2012
    'Som
    thanks- I think I get what you are saying:duh::confused::D
    I'll wait to the block turns up and see how I am going to route the loops on this one.
    Keep up the good work!!:rock:
  13. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Hope this helps, if you need anything drop me a line :)
    I'm waiting for some critical parts to finish the build, while waiting I will show you how my EK reservoir is going to look...
    Golden stop fittings of course! :blush::blush:
    Waynio likes this.
  14. Telefonskaft
    Telefonskaft What's a Dremel?
    31 May 2011
    Damn, that look really great!
    PRON!
  15. Nutman
    21 Oct 2008
    Looks soooo sweet.
    I just wish that tube reservoirs made from extruded acrylics weren't so prone to cracking. :-/
  16. Ninety Eight
    Ninety Eight What's a Dremel?
    24 Jul 2012
    This is great work.
    I'm hoping to do something similar in the near future. Where do you order your Bitspower fittings from? I'm finding it difficult to find a retailer in the UK or Europe who can supply the full range of their products.
  17. bundymania
    bundymania Bastelorakel Industries Worldwide
    4 Jun 2009
    The golden Bitspower stuff looks fantastic !
  18. bulldogjeff
    2 Mar 2010
    I love this build, so neat and tidy.
  19. Waynio
    Waynio Relaxing
    20 Aug 2009
    Oh this is looking lovely xSoMBrAx. :D:clap:
    stars rep
  20. patrick171
    patrick171 What's a Dremel?
    5 Jun 2011
    Please don't use this. Go for an aquacomputer aqualis. A premium build deserves a premium reservoir :) .
